Originally Posted By: swalve
The theory is probably sound, but it's also probably ineffective or even detrimental in a normally tuned engine. Do we even know gasoline likes a hotter, faster spark?
At the very least, I have to think there is a little delay while the charge builds in the cap, and this caused the engine to run like it's retarded a little.
The answer is, yes a hotter spark plasma will help ignition of fuel.
There is no delay for the capacitor. It is in parallel with the spark gap. It charges as the voltage across the gap ramps up to 20 kV and then discharges when the gap discharges. It essentially provides additional energy for the spark corona.
This is not snake oil. Enerpulse developed and patented the technology fairly recently.
US 2007/0262721 A1
Publication Date, Nov 15, 2007
Provisional Application filed on May 12, 2006
Enerpulse Pulstar Spark Plug Patent
The technology and science is solid. There should be no impact on ignition timing, since the plug fires in exactly the same way that all other sparkplugs do. The only difference is a capacitor in the body, near the tip, that stores about .125 Joules of energy while the ignition coil is ramping up to the spark breakdown voltage. When the sparkgap breaks down, the capacitor discharges, increasing the spark energy, and increasing the plasma discharge.
Whether or not this plug increases torque (and therefore power) depends on how good the head is designed and how good the combustion process is. In some cases, there will be no impact. In others, there could very well be gains, especially with rich fuel mixtures, high compression ratios, or direct injection.
There is an SAE paper on the early investigations they did into the technology.
Automotive Ignition Transfer Efficiency
Robert Bosch is investigating novel spark plugs for the same reasons.
"A Novel Spark-Plug for Improved Ignition in Engines
With Gasoline Direct Injection (GDI)", Klaus Linkenheil, Hans-Oliver Ruoß, Member, IEEE, Thomas Grau, Member, IEEE, Jürgen Seidel, and
Wolfgang Heinrich, Senior Member, IEEE, IEEE TRANSACTIONS ON PLASMA SCIENCE, VOL. 33, NO. 5, OCTOBER 2005, pp1696-1702
Abstract—Gasoline direct injection (GDI) is one of the future engine
concepts offering a significant increase in efficiency of automotive
engines. In this technique, the gasoline spray is directly injected
into the combustion chamber, which yields a strongly inhomogeneous
air-gasoline mixture. Hence, it is difficult to maintain
reliable ignition using a conventional spark-plug. In this paper, a
novel spark-plug based on a coaxial microwave resonator is presented.
First, the design of the resonator is described. Then its capability
of generating plasma in the pressure range up to 5 bar
(3750 torr) is evaluated. Finally, some results of gasoline ignition
experiments in a combustion chamber are presented.
Index Terms—Automotive applications, coaxial resonator, microwave
plasma, plasma torch, spark plug.
