Update. I'm an idiot. I put it back together with two rod caps swapped. This was not a good thing. Ended up spinning a rod bearing on startup. Pulled it apart, replaced the bad bearings, and put it back together again [hopefully] correctly. I didn't bother measuring anything, I figure it will either last another 100K miles or it won't, but there isn't much I can do for it now.
Waiting for the Permatex to cure before putting oil in it again and firing it up.
Usually I double, triple check this sort of thing, but I didn't feel like second guessing myself this time around as 99/100 it just ends up being a waste of time. I guess the lesson is, that 1/100 time may be important. Oh well.
robert
