quote:
Originally posted by Cressida:
*-*-*-*-*Reading the marketing material they really emphasised their PTFE additives and how it was the slipperest substance on the planet. I elected to pass because of that
I would too in most instances.
In general I agree with a lot of what they guys think on PTFE, but yet some points I don't. I mean WHERE are the tests that PROVE it is a failure, or least if the particle is small enough, yeah okay maybe it in some cases tends to stick in one area, but does that mean that there can't be a formula where it won't be beneficial?
I think in real old engines maybe worn with burning problems, SURE, MUST go for it, I would, heck I've done the RESTORE several times and you know what it worked. I even did more than one PTFE before, a couple worked per se and the rest I donno.... but that doesn't mean that it couldn't benefit you on at least GAS milage, and if the WEAR numbers stay about the same, or say go up very very slight, then IMVHO it may well be worth the use. It all depends on Goals and application.
Who cares if it is the best, if it cost 5-gillion dollars, when something at 1Billion will go the distance and pay for itself, to me that is the best (pay for your way).
Point is I don't think a lot of people will agree with me but you have to understand, Somethings gotta give some place. Got to, there's no free lunch except from Momma. Either the Oil will WEAR and cost money or the Engine will, and for certain they both will, but at what rate do YOU/I what EACH to WEAR. This IMHO is the REAL question no one has brought up. What is the ROI? What is the NUMBER / Ratio that's most cost effective, where's the formula to figure out (we need a bean counter here) What price to pay for oil and for how many miles that's cost effective for THIS CAR.
I'm still thinking of doing the additive test, I just don't know about which one, because although I think it may be beneficial, it (PTFE) I am sure has more than one quality/grade just like or I assume Silicon and other additives. And I'm sure that there are ones that do better than others.
No, I'm not just gonna pick just any one off the shelf, If I do this I'm gonna figure it out right or wrong and weigh all the facts and attempt to weed out all the fable, and here or any board on the web has both... then I'll shoot for it.
