About 18 months ago, I replaced my Steering gear because it was leaking badly. I had put off the job for a couple years, mostly because Lucas PS stop leak actually worked for a long while, except after a really long drive.
When I replaced the gear, I flushed the pump with 2 quarts of PSF, ran it closed loop with a cheap fuel filter, drained it again and made use of a magnefine filter on the return line.
Now I am noticing it is dripping slowly from the pump body, but have not yet determined where from. Is this a case of the Lucas swelling the seals in the pump, and now that I am not running the stop leak formulation, they have contracted and have started leaking?
Since I still have a pint of Lucas Left over, I am thinking of doing the turkey baster thing and replacing some fluid with Lucas PS stop leak. Bad Idea?
I also have not been able to find a new PS pump online, only Reman, and I have not heard anything good about reman PS pumps. I see the rebuild kits cost about the same as a reman pump. Are specialty tools required to install the rebuild kit?
Thanks
Thanks
