PS Fluid - This fluid ok?
Scituate MA
I am using turkey baster method for PS. 02 Grand Caravan 3.3. I have some Castrol ATF 4 and some Mopar ATF 4. Could I use either?
02 Camry same thing?
02 Camry is Dex III. Been "basting" my 02 every oil change with Maxlife Dex/Merc because the racks are prone to leak over the miles.
As for ATF+4; it all has to meet rather strict specifications and its all basically the same anyhow. In a PSF application it doesn't matter to even mix and match the two ATF+4's. I'd probably use whatever a Camry calls for if its Dex though.
Dont suck out the fluid in the Caravan.Replace the reservoir,these have a fine screen that gets junked up and leads to whine and chatter.You are looking at high $20s for a new one.
Good tip. Could be a great tip.
Maybe it is visible[first]and can be determined if it is bad?
I'd probably take it off and clean it, then replace it.
0$.
