ATF/PS fluid question RE: 2003 Camry
Greenville S.C.
I need to top off the power steering fluid in my 2003 Camry, and the manual calls for Dexron 2 or 3 ATF fluid. I happen to have a bottle of Subaru ATF-HP. Can I use that in place of Dexron 2 or 3?
Well $10
Short answer: Yes
Long answer: supertech dex/merc 3 atf is about $5 at wallys but atf type hp is the dexron 3 equivalent of subaru from before. It's just a hydraulic pump with hydraulic lines, a fluid that's nearly identical will work. Toyota also used dex 3 in their transmissions called t-iv but stopped using it since drain intervals weren't good but you could use the better allison TES fluids in the old toyota transmissions like you could in GM transmissions or the newer dexron vi but not the newer WS from what I understand.
The older dex 3 generation fluids were thicker around 7-8 cst kv 100 and progressively got thinner after that. now it's down to 4 cst. If you use a fluid thinner than spec you could have low pressure issues and more noise or more wear but it's usually the low pressure that causes the main issue. I know some hondas do require some fancy power steering fluid since it's super thick for a power steering fluid at 12 cst and does use a good bit of zddp like hydraulic oil unless it's agricultural spec which can't have any incase it spills into crops. I'd imagine a power steering system having issues if the fluid is half or less than half as thick.
https://msdspds.castrol.com/bpglis/FusionPDS.nsf/Files/A91E6EB4FA471EE980257C23008125A1/$File/ATF Dex III_467172_2013_10.pdf
I have no problem getting a new bottle of atf (thanks for the responses) but it's wild that you can't find any explanations from any manufacturer or other credible source anywhere describing the difference or why ATF-HP can't be used in place of Dexron 3.
Thanks! Any suggestion as to the correct stuff ..... or just pick one that's a match on the WalMart/Advance/Autozone/O'Reily's/NAPA website?
I just bought a gallon of Dex/Merc Valvoline for a PS flush in my 4Runner. They carry it at Walmart. The Toyota guys like it just fine.
