Originally Posted By: Quest
for my wifey's 04 camry (bought w/ 58k on odo, we are the 2nd owner), I used turkey baster to change the power steering fluid fluid.1st time change I added AutoRx to clean/rinse whatever in the system, then filled with Walmart/Supatech power steering fluid(clear/light amber colour). Since then, I would routinely perform blast-n-fill in smaller quantities yearly, no whines not anything so far (car now is over 162K).
Yes, power steering fluid does run hot and will gradually "boil off" over time, citing a recent scenario where my friend's dad 99 corolla (*yes, that dreaded, much talked about oil burning one, but in his case: 1 qt every 5k OCI @254k on odo, all previous oil changes done by stealership bulk) developed a light squeal during 1st start in the morning. Upon close inspection: power steering fluid fluid was extremely low (no leaks)and a lot of brown lumpy stuff sitting at the bottom of the reservoir. Service records showed no servicing done to the power steering fluid system all these years of former owner's ownership. I topped up the fluid with some power steering fluid and added autoRx and will do the turkey baster drain-n-fill this summer.
Q.
Your suppose to drain all the PS fluid out after putting Auto RX in and 1000 miles. Don't know if it would matter to leave it in longer while changing out some of it with turkey baster. I recently started using a hair shampoo pump and find it much easier to use than the turkey baster. Whoever recommended that, thanks.
