Pros and Cons of a Dually
A dually isn't needed for a 12,000 lb fifth wheel. Mine is 33' and weighs 11,000. I've pulled it for 5 years with either a '07 Ram 3500 SRW or the 2500HD in my signature.
It gets awfully breezy in some areas of Washington. I've never felt like the truck wasn't in complete control.
Originally Posted By: DesertDually
Originally Posted By: SteveSRT8
Our current RV weighs just under 13k pounds and is set up as a fifth wheel with about 4500 pounds on the tongue.
I can assure you after hauling it all over this country in all kinds of weather, up and down mountains, and on paved and unpaved roads I have NEVER felt a need for dual rear wheels. Snowstorms, thunderstorms, mountain winds, etc.
If you hitch to your bumper the difference is huge, but with a long wheelbase 2500HD Dmax and a fifth wheel setup you will not need anything more.
Yeah, I was speaking more from a bumper-pull perspective.
Or if you get a large truck camper, my uncle has a big one and ended up with a dually after having an older 2500 GM diesel with airbags and high capacity rear tires blown up hard as rocks... Still swayed and wandered he found. The dually is now a 3500 GM diesel which drives much better with the camper on or off he finds.
Pros: dually has that bad butt factor(G-rated), Stability hauling heavy loads,
Cons: 6 tires= $$$$, snow traction is not good in a 2wd, Some may find them harder to drive/ park. I don't have any issues driving and don't mind backing in a corner spot out in the back 50, as I need the exercise.
Originally Posted By: Chris142
Originally Posted By: cadfaeltex
Don't think I mentioned the weight of the trailer. The one we saw that we really liked was a tad over 12,000lbs dry weight.
Check your laws. you may need a CDL to pull that much weight. Sometimes they give RV's a break but usually any trailer over 10k requires a Class A CDL.
The rear end of a dully is super stiff w/o weight on it.
man, they need to send the legislature home out there in CA. ours meets for 140 days every 2 years.
hard to fathom, needing a commercial license to drive a pickup with a trailer.
