I'm doing in-house qualification testing on a system for which my customer will be using a propylene glycol fluid. He has a corporate mandate for the fluid, but no brands or products are mentioned. He has required us to use a propylene glycol fluid at a 40% concentration.
On the web, I find that Dow has UCON and LubeCorp has Lubritherm All-Temp. Neither are stocked locally (upstate SC). While this is a positive displacement hydraulic system, the pressure is low (under 250 psi for sure) and I'd consider Prestone LowTox or Peak Sierra; I suspect there to be sufficient lubricity for our tests. The RV products have no lubricity additives at all from what I have been told, and won't work with a positive displacement pump.
Do any of you have other products you would recommend? The test setup won't need but about 10 gallons of 100% fluid.
Thanks!
Thanks!
