Did he send off a used Jeans analysis?
Back already?I'm about to go stick both clean and dirty jeans in my freezer and film it.
Might even do motor oil.
Every Cowboy wears a Jean like that or longer that's actually to short you figure out the answer let me know BTW I wear a 30 36 or 38 easy to find you just shopping in wrong place.
Back when I laid block/brick Carhartt's were the only thing that would hold up until the Wrangler Rugged Wear came out.Not sure exactly the point of this one is... going to depend on the user and the way they are used...
That being said, Carhartt Traditional Fit / Straight leg jeans are the "standard" day to day jean in my usage. My work uniform is basically these, Red Wing Steel toe boots, and a polo shirt/button down shirt/or heavier when cold... (Then add the PPE on top of it...)
We're going to need a VJA first, then then we can do a UJA.Did he send off a used Jeans analysis?
That's the problem Kohls shop at a true western tack shop I'm 6'1I go to Kohls. You have a 30" waist and wear a 36-38 inseam? You are really tall and skinny.
It is not the heat it is the humidity !I live in Florida, I've not worn jeans in decades! It's too hot.
AmenI live in Florida, I've not worn jeans in decades! It's too hot.
Not according to the jeans forums. LolI saw this the other day. I must admit that Project Farm is a lot better at testing jeans than he is at testing motor oil.
