I had my friend's 2006 Prius aligned by the geniuses at Pep Boys. Here are the results:
Most of the initial readings have been removed since they were were erroneous. You can thank the geniuses for that-- they did something during the initial setup that goofed the readings.
Nevertheless, here are a few observations:
1) The steering wheel is a bit off center--it's clocked slightly to the right. This is probably due to the fact that the geniuses did not use a steering wheel holder when they performed the alignment. I'll take the car to a different Pep Boys and have it realigned soon.
2) The RF camber is at -1.4 degrees. The car pulls slightly to the right. Not sure what is causing it though since according to the results, the car should be pulling to the left.
3) Pep Boys wanted $107 ($46 for the part, $61 for the labor) to install a RF camber bolt to correct the camber. Instead, I ordered a Moog "Fast Cam" bolt, part # K90475 for $17 shipped from RockAuto. Supposedly, this bolt will offer one degree of either positive or negative adjustment. Since I need exactly one degree of positive adjustment in this situation, would installing the bolt and setting the bolt to the "max positive setting" correct my camber problem?
4) Although I am going to install the bolt before taking the car back in for another alignment, how far off will my toe be after installing the camber bolt?
Thanks!
Thanks!
