Sears Craftsman (MTD) with manual 4-way control chute aka joystick with release button freezes on me. I thought I had broken it today after I forced the release button but fortunately after the snow thrower sat in the garage for few hours, the button is working again. Peeking inside the mechanism, I see rust. I do not see any easy way to remove the assembly and bring it inside so I am limited to spraying chemicals inside. This is what I have
1) Kroil
2) WD-40
3) Lockease spray
4) Silicon Spray
5) White Lithium Grease
6) Slick50 One Lube
7) Primis Lube Gel
8) Ultra Lube 4x
9) 1Z Ultra Gel Spray Grease
I have got other greases such as SuperLube and Honda Shin Etsu and NAPA SilGlyde but those are in the tune format and can not be sprayed.
Most products don't list the temperature range, otherwise I would have chosen the one listing cold temperature operation.
Please suggest something which can resist the snow/water causing it to ice up and freeze.
1) Kroil
2) WD-40
3) Lockease spray
4) Silicon Spray
6) Slick50 One Lube
7) Primis Lube Gel
8) Ultra Lube 4x
