I saw a post about going in for a tire rotation and balance, which got me thinking about routine tire maintenance. I searched around but didn’t find much on the subject.
How often are you balancing your tires? And how often are you checking alignment?
I typically rotate every 5k and check alignment around 10-15k, or sooner if I notice uneven wear. I’ve never really considered rebalancing outside of when new tires are installed. Once they’re mounted and balanced, I’ve always assumed they’re good unless there’s a vibration.
