Originally Posted By: ltslimjim
Could be an ABS thing.
But it is good practice with any system to open the bleeder when retracting caliper pistons.
If the brake line leading to your wheels @ the caliper is rubber, one could also pinch the line with needle nose vice grips that have rubber stuck on them for safely using, and not allow fluid from the caliper depress to push fluid towards the reservoir.
That + always crack open the bleeder, do w/e job and bleed that wheel for air again after is the way I'd do it.
You shouldn't pinch a brake hose, it'll likely damage them.
I don't see how if rubber is pinching rubber, I've seen so many mechanics do this just enough to prevent free blow of fluid without pressure at the brake pedal.
Pinching off brake lines can damage the hose:
http://www.brakequip.com/rubber.html look at the construction picture of a typical DOT rubber hose and I would think that pinching off a rubber line could damage it (not so much the EPDM but I could see the PVA reinforcements not being as flexible as the EPDM). I was also taught in my brakes and suspension class that you shouldn't pinch off a rubber brake line/hose.
