Covering? Covering what? Just using your tire example, I would bet that if you advertised a tire that would hold air for 5 years, people would actually not check them. why? Because people are led to believe what they are told. to prove my point, go in your kitchen cabinet and look at the date code on your can of green beans. I bet you never throw it out early, or in your case, you probably never even check the date, but you eat that can without a thought, not knowing if maybe the advertised date is too far off, or that their date is too long.
Now for your personal attack, there is no self-interested bias. truth is, if something is advertised to last a certain time, it should perform it. I work in aviation where dates and change times are a daily fact of parts life. If I install a part, and the manufacturer says if goes for 1 year or 5000 hrs, it doesn't get changed earlier than that, unless there is an obvious failure, Why? because the MFG says so, parts are $$, and downtime does not pay. Remember that when your flying high on your way to your vacation destination. I will guarantee that the airliner carrying you is not getting shut down earlier to change its oil, hoses, or other fluids "because XX amount of hours usage recommended by the MFG of the fluid" seems too long. And that goes without saying that lives are at stake as well.
AS for your spark plug attack, yes, I left them in for the recommended K interval on my Santa Fe, and had absolutely no issues removing or installing them, nor where the plugs in bad shape, either. Maybe you just need to look at things in a different light rather than attack someone because they follow a different maintenance routine, or expect a product advertised to last a certain time, to actually last.
