Set them to 44 PSI MAX (first thing in the morning, before the car is driven..... - or late at night after the car has sat for 3+ hours) - if they feel too "hard", then lower them to 42, 40, etc....til you find that "sweet spot"....
The higher the pressure, the more "responsive" the tires will be as you go into turns, stop, etc......you may also feel that the wheels ride like a "rock" lol.....i.e.: you'll feel every bump and pebble in the road
The lower the pressure you go, the more "comfort" you will have while driving......the lower the pressure, the more 'flex' the sidewall will have as well.
Obviously, for best fuel economy, you'll attain that at 44 PSI.....but you don't want to sacrifice your handling either to save a couple pennies
And a side note: the early morning, or late night PSI check, is for the "Max COLD" PSI.....cold being defined as, not being driven for 3 hours.....
Monthly, I check my PSI in all my tires, and I typically will check the pressure twice, 2 days back to back, just to rule out any variance in pressure.....call me redundant....but there was one time it was a little bit "off" the next morning.....
And never "let out" air, from a "warm" tire.....as the tires are driven, the air expands, so they will "read" a higher PSI after say, a long road trip
Now that doesn't mean don't check your tire pressure while on a road trip....it just means do not REMOVE air, while on a road trip, if your tires are reading "over" the Max PSI mark.....since the "Max PSI" number is for "cold" tires, having not been driven for 3 hours........or driven less than 1 mile I believe (to give you some leeway to get to an air pump).
Another reason why I say to check the tire PSI back to back, 2 days
The air gauges on the gas station pumps are usually NEVER right, since they get dragged, dropped, ran over, etc......
[censored], even my 250 PSI portable 12v tire inflator was "off" by about 10 psi yesterday when I checked my PSI......the inflator noted 30 PSI, and my tire gauge said 20........tempted to return it.....but it does fill the tires
Which was what I wanted hehehe.....I got loads of tire gauges heh.
