I am looking to replace the OEM Conti ProContacts on my 2014 Altima 2.5 SL with either the Michelin Premier A/S or the Pirelli P7 A/S Plus.
In reviewing the specs on the P7 A/S Plus on the Tire Rack website, I noted the max inflation pressure for the "V" rated tire as 51 psi.
I have yet to own a set of "H" or "V" skins that had a max inflation pressure above 44 psi. Interestingly enough, the same
tire in an "H" rating lists a max Inflation pressure of 44 psi.
I run 35/32 psi in the fwd Altima. The weight of the engine over the tires somewhat dictates a higher psi than in the rear tires with minimal weight in the tail end.
Could I run 39/35 psi on those P7s (alignment and balance being in spec) based on the higher max sidewall pressure and still not cause pre-mature wear?
