It took me three hours with my small electric pressure washer, Sun Joe SPX2598 1500 psi/ 1.2 gpm, to clean the patio.
![Backyard Patio Aug23.JPG Backyard Patio Aug23.JPG](https://bobistheoilguy.com/forums/data/attachments/176/176094-5bf82e29a7ccb2ca9e78c27787f0bbee.jpg)
The patio is about 30 ft by 15 ft. The stones cleaned up nicely. I was covered in mud when I was done and so was the white stucco of the house. I washed out the mud from the stucco with the garden hose. I did not use any bleach or any chemical at all, just cold water. What was on the surface of the stones was organic green matter, from decomposing leaves etc.
I read about the surface cleaner attachment. Home Depot has a 12 in Ryobi
www.homedepot.ca
Is it worth getting?
Ryobi has a 2700psi/1.1gpm pressure washer
www.homedepot.ca
Does this have enough output to drive the surface cleaner?
Does the surface cleaner clean the joints between the stones? I noticed that the joints were quite a bit harder to clean than the surface of the stones. Spraying the joints with just the wand kicks up a lot of mud, no matter how the wand is aimed. Is there an attachment to clean joints, or at least contain the flying mud?
![Patio Stone Joint Aug23.JPG Patio Stone Joint Aug23.JPG](https://bobistheoilguy.com/forums/data/attachments/176/176095-e97ab4624943e9631f1f159ef585dd7b.jpg)
![www.homedepot.ca](https://images.homedepot.ca/productimages/p_1001058680.jpg?product-images=l)
RYOBI 12-Inch 2,300 PSI Electric Pressure Washers Surface Cleaner | The Home Depot Canada
The RYOBI 12-Inch Electric Surface Cleaner is the ideal choice for hard surfaces like driveways, patios, and sidewalks. This time saving accessory cleans up to 4X faster than a standard nozzle, with rotating jets that give you a large, streak-free clearing path. The surface cleaner has a...
![www.homedepot.ca](https://www.homedepot.ca/content/dam/homedepot/images/static/meta/favicons/en/android-chrome-192x192.png)
![www.homedepot.ca](https://images.homedepot.ca/productimages/p_1001708880.jpg?product-images=l)
RYOBI 2700 PSI 1.1 GPM Cold Water Electric Pressure Washer | The Home Depot Canada
The RYOBI 2700 PSI 1.1 GPM Brushless Electric Pressure Washer delivers the power you need without the hassle of gas. Delivering up to 2700 PSI and 1.1 GPM, use this pressure washer to power through dirt, grime, and other tough stains. This pressure washer features a powerful 13 Amp high...
