Pressure Washer hose for 3,100 psi Ryobi
North Augusta, SC
I bought this hose from Amazon about 1-1/2 years ago to use with my Ryobi pressure washer. I don't use it very often...mostly to wash the house so I can keep the pressure washer in one spot and not have to drag it around. The item is:
YAMATIC Kink Resistant 3200 PSI 1/4" 50 FT High Pressure Washer Hose Replacement With M22-14mm Brass Thread (Premium Upgrade Version 2X)
When in use, both ends of the hose leak where the hose is crimped to the fittings that connect the wand and washer. In addition, I see that the covering iboth s starting to bubble in places....maybe indicating that the hose inside is coming apart. Anyway...can someone recommend a decent quality replacement hose?
