Hello, I purchased my del sol from a cheapo dealer that said the clutch was replaced. However I suspect that's all he replaced was the friction disc. The transmission seems generally noisy to some degree, no major rattling like an input/release bearing and no grinding.
I noticed that the clutch starts to catch early but doesn't really fully engage till near the top. I also noticed there is a lot of grabbing at low speeds with 1st gear. Could this be a symptom of a worn Pressure plate?
Reverse seems to engage stronger than the normal upshift gears.
