- Joined
- Sep 28, 2002
- Messages
- 39,793
I've was discussing a few things with another member back channel. He was seeking a stand alone pressure relief in sensible pressure ranges for out level of need. He finally found a check valve (sprung ball type) that could have any breaking pressure spring installed from 0-100 PSID. It wasn't cheap (about $40) ..but that's comparable with the Permacool thermostat in price ..and about half the price of a Mocol.
This leads us to our opinion forum of the moment. What's your opinion upone either method for flow regulation in terms of auxilliary coolers and filtration? Each has its advantages and limitations.
I've observed serveral modalities used in OEM installations, mainly Fords. They use a simple sandwich with an internal pressure relief vrey like Permacools. It just sets the max amount of pressure seen across the cooler circuit. Thinner oil ..assumed to be hotter, more flow through the cooler circuit. Simple and reliable. As long as you're using a spec'd visc oil ..and everything stays nice and tidy ..you should have long term reliability and adaptive cooling as needed. The advantage to this setup is that you can dial in your pressure drop/elevation across any downstream add-ons. The disadvantage is that it's numb to anything except pressure.
Thermostats off you the advantage of assuring a given oil temp before you see any additional effects of you add-ons (either cooling or filtration) ..but are totally numb to the pressure drops/elevations that may occur even though you've heated the oil to 180°F. They are numb to anything besides temp.
Anyone have any opinions they would like to share? Things to consider ..compound setups ..and just what does anyone think is a reasonable pressure drop/elevation to tolerate across any add-on???
