This is a series of pictures of a pg241 that was on a 2002 suzuki aerio at least 2 years ,but i am not sure how many miles. Probably very little. The filter is the same as most 1.6 and 1.8 toyota's. It is made in Thailand or china from what i have found
I have owned the car for almost 2 years ,but just got it back on the road. It only has 76000 miles ,but its history is unknown. It needed some body and paint work that is finally done.
The motor has a intermittent valve or heat shield clatter on cold starts. I wanted to see if changing the oil to 0w20 toyota full synthetic mixed with a half quart of mobil 1 15w50 would quiet it. I also switched filters to a toyota 90915-yzza1 that I have a stash of. The old oil was a who knows what mix that I added almost 2/3 quart of mmo. Don't ask unless you want the whole story on that too.
Back to the filter . The can is very robust. I could barely cut it open with my grinder. I also see some serious flaws in the media construction. The paper is brittle and crunchy , maybe from sitting in oil, maybe not. The filter has also twisted the media clockwise . I have seen this in other posts on this filter. Some were more serious that this. Here are the pictures. If you can tell from my [censored] photography , check out the design.
By double1trouble1 at 2011-05-15
Anyone else use these? What do you think ?
