I fixed that for you.If it has a turbo, it needs premium for maximum performance. Some companies say you can use regular in them, but it's not a good idea![]()
Depending on the engine.Higher compression gives better gas mileage and more power.
My VW 1.4tsi dint need premium. It has same performance and fuel; mileage with regular. In fact it had snappier throttle response with regular. I guess it's Direct Injection magic. I am one to give the engine higher octane if it wants it.I fixed that for you.
I suspect the majority of Lexus vehicles are driven in such a way where the owner wouldn't experience a difference between 87 and 93.What most don't understand, is that ALL manufacturers perform testing on premium fuel... even Lexus
This is what their performance numbers are based on.
The funny thing with Lexus, is that the previous generations of RX were specced for premium and as a result they performed flawlessly.
The newer versions aren't....so what changed machanically? Nothing!
Lexus realized that most people cross-shopping an RX with anything else will balk at running premium...but regular- now we're SAVING money
Sure, the Lexus will run on regular, but it may run slightly rougher, consume a little MORE fuel, and take a little longer to start.
This is the difference between "recommended" and "required" octane ratings
But hey, we're saving money!
I've never seen a paper or study showing a connection between LSPI events and fuel octane rating. Have you? LSPI and regular pre-ignition knocking are not the same thing and have different causes.I am concerned about LSPI, so I run the best fuel I can find, non-ethanol, premium, 91 octane in my BMW turbo (B46tu engine).
The owner's manual "recommends" 91 octane to get advertised HP and fuel economy. The minimum "recommended" fuel is 89 octane. They state that 89 octane "may produce knocking sounds". Premium may cost a little more, but the car sips fuel, (avg 30 mpg) so I don't really care.
