Originally Posted By: WobblyElvis
My own opinion.
There is no advantage to premium fuel unless your car manufacturer calls for it. Higher octane fuels run dirtier and that's why they have to have extra cleaners. You may be slightly better mileage with high octane fuels but not enough to justify the cost. Fuel dilution? Wouldn't higher combustion pressures, from advanced timing, force more gases past the rings?
You're correct for port injected engines of nominal 8-9.5:1 compression ratio that dominated for 20-30 years. Unless you made changes to the engine to take advantage of the premium it rarely if ever would increase power & economy enough to justify the expense.
Whats going on is since these GTDI engines are running so much pressure they would risk detonation, so in order to try to combat this they run rich if you feed them 87 to try and cool the combustion chambers. Since there is excessive fuel not all of it vaporizes, and some of it lands on the cylinder wall. First of all, the piston is going down on the intake stroke during injection. If not every little bit of the fuel that landed on the swept bore of the engine vaporizes before the piston comes back up on compression, the rings will wipe it, and some fuel will make it past them.
Second thing is, liquid unleaded does not go bang. It has to vaporize into a mixture with air. A fuel/air bomb if you will. So any liquid the rings might have pushed up will not burn fully either providing more time for fuel to leak past the rings.
I mean we are talking about such a small amount of fuel escaping during a single cycle its almost immeasurable. If it was a ml of fuel past the rings every combustion cycle on every cylinder you'd fill the crankcase and have raw fuel coming out the dipstick tube in a few miles.
Giving it premium really is giving these GTDI engines the fuel they were designed for. They can run hotter and leaner, promoting better vaporization of the fuel. The OEMs will tell you you can run 87 because they want you to buy the car, and for many people, having to spend an extra $.30/gallon for premium is a deal breaker. So they program these engines to accommodate that. So what if the fuel in the lube causes higher timing chain wear, higher piston ring wear, or whatever? It'll last through the warranty period; thats all they care about.
