If it is a Euro Oil it has to be like 10 or so. What I am saying is there are quite a few Euro Specs, 229, Porsche A30 and A40, probably some others. Look at the specs this PP Euro meets, you should be able to find that on the back of the Bottle of oil.Hello all
The PDS doesn't list this does anyone know what it is or where I can find it?
Thanks for any assistance
OP is asking about a different oil than the one pictured in your linked thread.Penzoil Platinum Euro L
I've done some searching on BITOG about this particular Penzoil Platinum Euro oil, however this has to do with the "L" designation in the name of the oil: Penzoil Platinum Euro L. Now from what I can see L seems to be restricted to the 5w30 variety, and the 5w30 is the exact oil I'm looking for...bobistheoilguy.com
This Thread should help, well at least the back of the Bottle of Oil.
It doesn't matter, because PP Euro 0W-40 lacks the Porsche A40 OEM approval. That approval for me is a performance guarantee and zero foaming.Hello all
My mistake, but both 5W-30 and 0W-40 of this fantastic Euro Oil from Pennzoil should meet the same specs? Am I missing something here?OP is asking about a different oil than the one pictured in your linked thread.
Euro L 5W-30 is C3.My mistake, but both 5W-30 and 0W-40 of this fantastic Euro Oil from Pennzoil should meet the same specs? Am I missing something here?
Is there another 0W40 that does that you would recommend?It doesn't matter, because PP Euro 0W-40 lacks the Porsche A40 OEM approval. That approval for me is a performance guarantee and zero foaming.
Mobil 1 FS 0W-40. Easily available at Walmart, most of the time on sale, and it's Porsche A40 OEM approved.Is there another 0W40 that does that you would recommend?
Avoided M1 because of it's high Ca content as someone said this causes LSPI in low displacement GTDI vehicles which is what I have.Mobil 1 FS 0W-40. Easily available at Walmart, most of the time on sale, and it's Porsche A40 OEM approved.
Edit:
If you want a good SOPUS product that is Porsche A40 OEM approved, I recommend Quaker State Euro 5W-40. It's very good oil, identical to PP Euro 5W-40 and Shell Helix Ultra 5W-40. It has a NOACK of about 5.4%. For example, I would pick this oil over Mobil 1 FS 5W-40 because amongst other things, it uses only high quality GTL as base oil.
New M1 API SP has low ca content.Avoided M1 because of it's high Ca content as someone said this causes LSPI in low displacement GTDI vehicles which is what I have.
It's for a car that has 5W20 spec'd but I've put in a bigger turbocharger and tuned it to double it's stock horsepower so I thought 0W40 would be a good compromise of improved protection for the turbocharger while keeping the viscosity closer to spec.
Is this line of thinking erroneous?
And it's not what causes it, engine design and operational envelope is what causes LSPI.Avoided M1 because of it's high Ca content as someone said this causes LSPI in low displacement GTDI vehicles which is what I have.
Also, not all TGDI engines have issues with LSPI. Generally, it is reserved for Asian and American small-displacement engines. Euro engines are not affected by it. Generally, if they re, it is usually poor aftermarket tuning.
LSPI - a marketing tool that helped sell a lot of oil for engines that should have been designed correctly in the first place, and then some. I don't even want to go down this rabbit hole today.And it's not what causes it, engine design and operational envelope is what causes LSPI.
Post some pictures of this bigger turbocharger.
LSPI is a marketing tool?LSPI - a marketing tool that helped sell a lot of oil for engines that should have been designed correctly in the first place, and then some. I don't even want to go down this rabbit hole today.![]()
It was used a tool to sell motor oil to people who didn't have engines that presented the slightest risk of LSPI.LSPI is a marketing tool?
Amsoil Euro 5W-40 EFM has a NOACK of 8.7, and I believe this is Porsche A40 approved. Let's put it another way, Amsoil now says it meets the approval. You are saying that PP Euro 5W-40 has a NOACK of about 5.4%. Is there any documentation that is out there that shows what you are saying. I really find it hard to believe that PP Euro 5W-40 has better NOACK Numbers than Mobil 1 FS 5W-40!Mobil 1 FS 0W-40. Easily available at Walmart, most of the time on sale, and it's Porsche A40 OEM approved.
Edit:
Shell Helix Ultra 5W-40 is the same exact oil as QS Euro 5W-40. Shell sells the same oil under three brands.Amsoil Euro 5W-40 EFM has a NOACK of 8.7, and I believe this is Porsche A40 approved. Let's put it another way, Amsoil now says it meets the approval. You are saying that PP Euro 5W-40 has a NOACK of about 5.4%. Is there any documentation that is out there that shows what you are saying. I really find it hard to believe that PP Euro 5W-40 has better NOACK Numbers than Mobil 1 FS 5W-40!
Invisible, this is not an Attack, I just want to see if I am missing something here.
As a non subscriber to conspiracy theory, I'm putting you on a need to know basis.It was used a tool to sell motor oil to people who didn't have engines that presented the slightest risk of LSPI.
Since you interjected yourself into this conversation, please explain to us what you know about LSPI. Why it happens, when it happens, in what kind of engines it happens, etc. I'm curious to know what you know.
Also, NOACK is 5.7%, not 5.4%. I stand corrected. It's been a while since I visited the site bellow.
So check it out here: https://hplu.be/fVxaP
Yes, it's very good oil, no matter how hard you'll find to believe it.
You might want to ease back on your strong enthusiasm. Find another hobby, I'm not that interesting.As a non subscriber to conspiracy theory, I'm putting you on a need to know basis.
You're missing something.A 5-quart jug of the QS goes for $22.97, but the Shell Helix goes for either $15.99 a quart or $66.63 for a 5 quart jug. Something is not adding up, unless I am missing something.
