The posting of these UOA's are always a challenge, this is my 2nd UOA on this vehicle. Blackstone ran this analysis. I was very happy with how PP handled the many short trips this van sees. There were some out of state trips in this run too, but the van is mostly a short tripper. The van was fully warmed up and I did note to the lab that I nearly forgot to pull a sample, so this oil was taken near the end of the drain. I was happy the fuel went down in this run. I put in QSUD 5w20 in for this current oil change, interested to see how that oil does.
Toyota 3.0L V-6 (1MZFE)MAKE/MODEL: OIL TYPE & GRADE: Pennzoil Platinum 5W/20 SM
OIL USE INTERVAL: 6,547 Miles
COMMENTS BRAD: It doesn't look like either the longer oil run or the fact that the sample was taken near the end of the drain altered
your engine's results. Metals are nearly perfectly steady since last time, and that's a great indication that the engine didn't mind
the extra miles on the oil. Chrome and copper have fluctuated by amere 1 ppm each, but that's not enough to worry about the health of this
engine. You shouldn't have any problems running your next oil longer since wear is quite steady and the TBN is still above 1.0 (it read 2.0).
Add 2,000 miles to your next fill. Nice report!
ELEMENTS IN PARTS PER MILLION
First number is new UOA, 2nd number is last years UOA
MI/HR on Oil 6,547 4,862
MI/HR on Unit 82,152 UNIT / 75,605
Sample Dates 02/17/12 & 04/16/11
Make Up Oil Added 0 qts
First number is most recent UOA, middle number is the universal averages, and the last number is the previous UOA from last year:
Code:
ALUMINUM 3 3 3
CHROMIUM 1 1 0
IRON 7 7 7
COPPER 3 4 2
LEAD 0 0 3
TIN 0 0 1
MOLYBDENUM 48 49 63
NICKEL 0 0 0
MANGANESE 0 0 0
SILVER 0 0 0
TITANIUM 0 0 0
POTASSIUM 2 2 2
BORON 11 20 28
SILICON 16 13 9
SODIUM 8 12 15
CALCIUM 2353 2360 2367
MAGNESIUM 10 11 11
PHOSPHORUS 606 607 607
ZINC 672 674 776
BARIUM 0 0 0
PROPERTIES -
again first number is the newest UOA,
middle number is averages and final number is previous UOA.
SUS Viscosity @ 210°F 50.7 46-59 53.7
cSt Viscosity @ 100°C 7.47 6.0-10.2 8.39
Flashpoint in °F 360 >355 330
Fuel %
Antifreeze % 0.0 0.0 0.0
Water % 0.0
Insolubles % 0.2
TBN 2.0 2.8
Advice and discussion encouraged!! Thanks all!
Code:
ALUMINUM 3 3 3
CHROMIUM 1 1 0
IRON 7 7 7
COPPER 3 4 2
LEAD 0 0 3
TIN 0 0 1
MOLYBDENUM 48 49 63
NICKEL 0 0 0
MANGANESE 0 0 0
SILVER 0 0 0
TITANIUM 0 0 0
POTASSIUM 2 2 2
BORON 11 20 28
SILICON 16 13 9
SODIUM 8 12 15
MAGNESIUM 10 11 11
ZINC 672 674 776
BARIUM 0 0 0
PROPERTIES -
Fuel %
Water % 0.0
Insolubles % 0.2
TBN 2.0 2.8
