Power Window Switch Repair
Bolivia
I finally got tired of wiggling the switches in my 325ic to the point where maybe I got contact. With new switches 4000 miles and many $$$$$ away, I figure I'd attack the problem.
In the end, each switch is about a 15 minute job to clean and rebuild.
Popping the switch apart, you find a few simple parts.
Pulling the buttons out you have the contacts that need cleaning
and sometimes a little straightening
Clean-up with fine sandpaper
A little conductive grease I had picked up at Home Depot
And it is ready for reassembly. Windows zip down and up with much better speed and ease.
A few more pics and comments here:
http://www.widman.biz/Corvair/English/Links/Window.html
Good job ! Most shops/dealers just take an easy way to fix the problem by changing out the old switch with a new one at great expense to owner.
Originally Posted By: Eddie
Most of todays "machanics" are really just parts changers.
That's because the labor charge of fixing the old one would exceed that of buying a new one.
Been there - done that, with many electrical problems. A common theme is relays that need their contacts cleaned after a while. My Mercedes has LOTS of relays. One clue is when electrical operation is intermittent.
I don't think you want one of our electrical techs cleaning a switch for $110 an hour. Same reason why you never see shops rebuild a master cylinder or a brake caliper. BTW we are one of the cheaper dealers in our town as far as labor rate goes.
You did notice that OP lives in Bolivia? I suspect they fix lot more stuff. We tend to replace them.
Even at $110 an hour, 15 min is less than the $40 + tax and shipping that the new switch costs.
And yes, we fix a lot more here.
Take a look at my Corvair site......
here is the Spare tire support I just made for my Corvair. It's first life was a motorcycle shock absorber, two bolts and a nut.
After a little welding, grinding and chroming, here it is
More details of that on my site too.
