A little background information: I have been replacing the drive belts of my 1994 Nissan Quest for the past few days and have been running into one issue after another. I had removed the passenger side wheel to gain access to the belts.
When the van is parked, and I turn the steering more than 5-10 degrees either way, it squeals pretty loud. The steering becomes fairly stiff, too. While driving, it still squeals, but the steering has to be turned around 30-40 degrees either way before the noise is sensed.
Trying to trace the noise all day long, I know the following:
(1) When the van is jacked up off the ground, regardless of whether the wheel still is on or not, there is no noise. The steering turns smoothly, too.
(2) When the van is on the ground, and one turns the steering, the squealing noise is accompanied with a temporary stoppage in the power steering pulley.
Since there is no squeal when the van is jacked up, it leads me to believe something goes wrong when the wheel touches the ground. I can’t seem to figure out what it is, though. Any ideas?
