Power steering fluid question '98 Continental
PA
The manual for my '98 Continental states that Mercon ATF should be used when adding or replacing the fluid.
I'm assuming that I can use Dexron II E / Mercon ATF, or would it be better to upgrade to a newer fluid...for example, Mercon V?
Thanks for any advice provided.
Mercon V is a perfect replacement for Mercon.
If you want the best upgrade, get some premium synthetic ATF.
Also, many Fords call for a certain ATF specification, but I find that any ATF works fine in Ford power steering systems.
Thank you, Artificialist...so, I can't do any harm using the Dexron IIE / Mercon ATF?
Although, it would be much better to use Mercon V, or a premium synthetic ATF.
That Dexron IIE/Mercon will do no harm to your power steering system.
DEX IIE is a very old spec...if you're talking about some leftover stuff you have laying around, I wouldn't use it. Also don't use Mercon V that is old...it was reformulated when Ford stopped licensing plain Mercon so as to be backward compatible, but the older formulation was not.
In both of my Mercurys I've replaced the fluid with Maxlife. I've done the same in the past with all of my Fords ranging in years from 1994-2007 with no problems.
I worked at the Ford power steering plant in Indy from 1990 to 2006; I was there when your steering pump, gear and column were made. IIRC you have the CIII pump and the Conti was a Taurus based variant, so it has an aluminum body R&P (chassis D186 is a stretched Taurus platform, if memory serves???) ...
You can use any Dex/Merc variant; the system just isn't that picky. From lowly house brand D/M fluids all the way up to Allision TES-295 licensed products, any Dex/Merc type fluid will suffice. Merc V is generaally considered as an upgraded Mercon variant; semi-syn with small chem tweaks.
It would be my suggestion to use a house brand Dex/Merc fluid; will save you money and your steering gear will never know the difference.
