power steering fluid for the track
will the flash point matter for track use? does the flash point have anything to do with "boiling over"?
Flash point defines the temperature at which a material ignites when in the presence of a flame. It wouldn’t have any direct connection with that.
I’d talk to a racing fluids company such as Red Line or HPL for this application.
How is a synthetic ATF not enough?
Do the rules forbid using a power steering cooler?
The most over kill off the shelf hydraulic fluid I can think of off the top of my head is mil-83282. It's an PAO Ester blend with a focus on combating the effects of high temperatures.
Define track use. There’s many cars doing SCCA or similar track days with the fluid that’s in their systems. I don’t think someone autocrossing a Miata/WRX/M3 is changing PSF.
Cop cars(Ford P71 Crown Vics/cop version of the Taurus and Explorer or the 9C1 RPO of the Impala/Tahoe/Silverado) have fluid coolers for the power steering system but they’re using regular PSF.
If it was me, I’d use a “synthetic” ATF or Pentosin CHF11. If you have a Honda, stick to the Honda stuff. Of course, “race” cars don’t have power steering(unless it’s a Prius/Versa EPS conversion, which has become popular in the hot rod community as of late).
Redline D4 resisted boiling/overflowing more than generic Dexron in my old car, but the large cooler and baffled reservoir I eventually added made far more of a difference. Granted that was for rallyx/autox with a steering quickener and modified pump, so far more constant back and forth steering inputs to stress the system. For track use like a road course, a good quality synthetic like Redline D4 (or whatever similar product that is compatible with your application) would probably be good enough.
thanks guys.
so when does psf boil over/foam (= spills over the engine)? does it have to do with the flash point? obviously po had this problem.
the synthetic recommended/available to me has a very low flashpoint of 166°c and they said it would not matter. i see redline and amsoil (the go to products in the u.s.) at 225/230°c, which makes me think a bit.
(there is D892, but i have no idea what it means and its usually not published.)
so i found a source for amsoil synthetic and am going to get it. 230°/250° flash/fire seems to make more sence.
on the subject:
