Originally Posted By: yeehaw1960
Oops, my soapbox broke. It must have come from Lowes!
Yes the box store equipment is not as well made and will not hold up to commercial use. But they share similar components. The carbs are made by the same people. If you have some skills with small equipment, box store equipment can be servicable.
One of the big differences is the set up & warranty. Two cycle eqipment often comes from the factory set lean, causing lean seize. A shop will set up and adjust equipment. The second point would be high end stuff has it's share of problems, but you have a dealer to make you feel better.
I have been repairing and donating to churches and those less fortunate, Poulan, AYP,MTD, Ryobi yard equipment that has been discarded in the township dumpsters.
It is often fuel lines and diaphrams on old or neglected equipment, or ring sieze on new equipment (set lean). Many cheap lawn tractors rust out, before mechanical failure. I have to admit, Poulan chainsaws are the most frustrating. I had one with an inconsistant hot start problem I never figured out.
If you buy some inexpensive carb tools and a couple manuals, small engines (2 & 4 cycle) are very easy to work on. It is not as glamourous as synchronizing carbs on a race bike, but it provides some sense of accomplishment.
