Did another spill and fill on my daughter's 2004 Escape. The fluid coming out was looking pretty decent so this might be the last for several thousand km. In went 3+ litres of convention Dex/Merc (finally found some cheap stuff).
Does the Atlas have have the Aisin 8 speed automatic in it? If so, how much trouble was the change?Auto trans service for the Atlas. 66K mi/7 Yeats. VW service recommended at 80K/8 years.
Yes. Not hard. Look at the FCP Euro video on this on YT.Does the Atlas have have the Aisin 8 speed automatic in it? If so, how much trouble was the change?
My Tiguan is about due. I will watch and consider doing it myself.Yes. Not hard. Look at the FCP Euro video on this on YT.
How many quarts did it take?Auto trans service for the Atlas. 66K mi/7 Yeats. VW service recommended at 80K/8 years.
It's an overfill/drain setup, I used a 4 qt bottle of ATF and probably drained a qt back out..maybe? Didn't measure it.How many quarts did it take?
How much did the dealer charge?2021 Jeep Grand Cherokee 4x4 3.6 75k miles
ZF 8 Speed Filter and fluid replacement Done at the dealer
Out : FF
In: Pan/Filter combo & Mopar 8&9 Speed fluid
It was about $800 for the Trans fluid/filter along with the transfer case and front/rear axle fluids.How much did the dealer charge?
That seems way too cheap. Are you sure they actually replaced the pan and used Mopar Fluid? The pan’s MSRP is $471 and the fluid’s MSRP is $35/qt.It was about $800 for the Trans fluid/filter along with the transfer case and front/rear axle fluids.
Did my Jeep 850RE for right at $150 ... OEM filter and Zeus juice 8It was $889 for everything, I had to go dig out the receipt.
The filters and fluid aren’t that expensive anymore or atleast what they were a few years ago. I know there’s a couple of Mopar stores listing them for high prices still online though which is ridiculous. I remember pricing it a few years ago for my 2015 Ram I had and it was about what you said then.
The Mopar filter from the dealer for the Jeeps ZF 8H50 was $253 through them. It takes about 6 quarts I think for just a pan drop. The Mopar fluid through the dealer was $23 a quart. Privately is even cheaper you can get a 6 quart case for less than $100 now on Amazon. They charged me $200 in labor. Which is not quite 2 hours since they charge me $125 a labor hour. The exhaust doesn’t have to be moved in the Jeep so the labor isn’t as extensive I guess.
They charged me $60 for the transfer case (which is still ATF +4) and $180 for both axle fluid drain and fills (which oddly enough it takes the same fluid for front and rear). Those prices include the fluid and labor.
Now I know the filter for my 2021 Ram is going to be more expensive. The ZF 8H75’s filter is considerably more expensive and the labor is a bit more. But I’ve got a couple more years before it’ll be due.
Wow, I was super nervous I’d screw something up so I psyched myself out of doing it myself especially with the extended warranty lolDid my Jeep 850RE for right at $150 ... OEM filter and Zeus juice 8
