post your latest transmission lubricant change.
2003 Corolla:
Out- unknown (Friend did not have receipts for last change)
In- Toyota Type- IV
270,003 miles.
I know my friend had it changed once or twice during his ownership. Pleasantly surprised with the fluid condition. Will do another drain and fill in the near future.
Did a plug drain on our new-to our family 2009 Honda Pilot. The fluid level was correct and about 3.5 quarts drained out. Not sure how many miles was on it but it was considerably darker than the new Honda DW-1 that went in.
The top plug was horizontal at the top of the transmission and was reachable from standing beside the front drivers side fender. It was over- tightened. It is about 16 inches from the top of the engine bay to the plug. A long 3/8 inch extension on the end of my Dewalt 921 could not shake the plug loose. I changed to two 8 inch long 1/2 inch extensions and was able to get it loose. I did all this prior to tackling the drain plug.
The bottom plug I got loose with a 1/2 inch ratchet crossed to a 3/8 inch extension. The plug had a magnet with a bit of fine metal.
I filled it with 3-1/2 quarts of new Honda DW-1. I’ll probably do another spill and fill later.
The top plug was horizontal at the top of the transmissionmission and was reachable from standing beside the front drivers side fender. It was over- tightened. It is about 16 inches from the top of the engine bay to the plug. A long 3/8 inch extension on the end of my Dewalt 921 could not shake the plug loose. I changed to two 8 inch long 1/2 inch extensions and was able to get it loose. I did all this prior to tackling the drain plug.
I never understood Honda transmission plugs. Why so dang tight?
My 23 Civic Type R is currently at a local shop having an Acuity 4-way adjustable shifter installed along with upgraded shift cable bushings. Since they will have to remove the airbox to get to the bushings I'm having them do a drain and fill on the manual transmission fluid although its only been about 15,000 miles since the transmission service. This mechanic is a Amsoil rep so I'm going with the Amsoil Synchromesh Manual Transmission Fluid. I would typically wrench on the car myself but just too busy with life and I'm impatient.
Did the drain and fill procedure on 2014 Toyota 4runner. Used fluid still a little translucent but was dark and sort of purple. Used Valvoline Maxlife ATF to add back what was taken out.
Did a pan drop, clean out and new filter and refilled with Idemitsu TLS-LV on my 2017 Tacoma TRD-Offroad today. It was still the OEM fluid, it was brown but not really burnt smelling just old, barely anything on the pan magnets. 1-2 and 2-3 upshift under light throttle is significantly smoother than before quite the improvement and it shifted fine as it was. I'll probably do another drain/fill after about 5,000 miles to get the system cleaner.
I've heard this is a good ATF for Toyotas.
Sure seems to work good I drove it tonight to get dinner and the whole truck feels significantly more responsive and better shifting. I only got like 4.5 quarts changed out of the whole system surprising it made that big of a difference.
New Transmission fluids in my 1997 Harley Classic Heritage.
I purchased my bike new 29 years ago and have done my own fluid changes 1-2 times a year average so this is my 29th to 60th fluid change in my old friend.
I stopped keeping records years ago but as a rule I simply change all my fluids and do a deep clean, detail wax every Fall & Spring the week before I go to Myrtle Beach Bike week. I have been known to skip the primary and transmission to every other oil change but its just as easy to keep all fresh fluids in the old girl, she likes it!
My thought is when a transmissionmission only holds a quart why not change the fluid more often than not?
This was my 60th Myrtle Beach Spring and Fall bike week this past May. Time flies when you're having fun...
I use Bel-Ray 85W -140 BiG Twin Transmissionmission Oil in all my Harley bikes, old to new= EZ to find Neutral, little to NO 1st gear CLUNK and Buttery smooth shifts... GOOD STUFF!
Why did you go back to OEM?
I have always been an OEM transmission fluid guy. When I first put the ML in, I got swept up in all the hype about it on here.
The reason I changed the filter again, is my wife said it was slipping on her twice taking off from a stop in first gear.
The fluid was right where it should be on the stick. It seemed quite dark to me.
Another twist I did not expect though: when I was cleaning the pan out, it almost seemed to me like there was some water in it. I was not looking for that or expecting it by any means. I was just dumping it and wiping it out. Also, the inside of the pan is black, not bare metal like many; making it a little tougher to see. How it would have gotten in there, I have no idea. The vent fitting and hose on top like fine.
Have driven a couple hundred miles since the change now, everything is great again.
Mazda 6 with the 5 speed FS5A-EL transmissionmission (from what I've read, this transmission is very similar to the Ford FNR5 transmissionmission found in the Ford Fusion, Ford Mercury etc).
At 125,000km (when I first purchased the car), I completed a "drain and fill" using Mazda M-V transmissionmission fluid.
At 150,000km, I completed a "drain, change filter, cleaned pan magnet and fill" using Aisin AFW+ fluid. Transmission shifts smoothly...
At the next transmission service (200,000km), I'll complete a "drain and fill" using Aisin AFW-VI fluid.
Yeah people love the MaxLife. Glad it’s working better for you.
