2006 Honda CR-V EX AWD (automatic transmission) 180k miles
Out - OEM Honda Fluid
In - Idemitsu Type H Plus 3.3 quarts initial fill
Performed a 2nd drain & refill all together got 6-6.5Qts of fluid revitalized2016 rogue s fwd. out factory cvt fluid 61k and swapped out cooler filter. Refilled with lubegard and beck arnley filter.
2007 Honda Fit Sport A/T with 323k miles
6.3 Qt Total Capacity
Each D&F = 3 Qt exchange
Out: Amsoil ATL (Blue Cap) 41k miles
In: Amsoil ATL (Blue Cap)
Old fluid still looked pretty good. Not the brightest pink, but only a shade darker. Could have gone another 10k safely. The magnetic drain plug had a very thin layer of wear metal.
Smooth as ever. Of course, I didn’t have many miles on previous fluid before swapping to Amsoil back in 2015; a few months after acquiring vehicle. That’s when I had a shop perform the cooler line flush over to Amsoil; swapping the external filter, too.How's the shifting with the AMSOIL ? Amazing mileage .
I've been using Maxlife for over 100k on the same transmission it's great stuff.2009 BMW 328i, 131k miles
Out: unknown, likely factory fill
IN: 13 quarts of Maxlife
Shifts are so smooth and effortless
I’m joining the Maxlife Cult
Hello,Did the pan drop and filter change.
Out: M1 ATF
In: M1 ATF
4 1/2 Qts
40K on the last fluid change
What year Fusion and which transmission?Hello,
I have a Ford Fusion SE with engine V6 - 3.0L engine, what do you recommend to use for that? Is Mercon 5 passable?
I am not sure of the transmission, it is a 2006, has 190K miles and I do not know when they changed the transmission fluid last.What year Fusion and which transmission?
It should have the Aisin AW-F21 in which case it uses Toyota T-IV or Mobil 3309 fluid. Do not put Mercon V fluid in it.I am not sure of the transmission, it is a 2006, has 190K miles and I do not know when they changed the transmission fluid last.
Sorry I am just now getting into learning about it!
