Post your latest small engine oil change
First change on my new to me Champion Inverter Generator model 100809. Ran it for 5 hours for the break in, and changed the oil.
Out: .5 quarts factory supplied oil (10W-30)
In .5 quarts Amsoil Small Engine oil (10W-30)
Changed the oil in my Craftsman T3200/3000 riding mower. Looking back on this site, I changed it last April 2021, used Co-op DMO CK4 semi synthetic 10w30 with Fram Toughguard. It saw little use that year and maybe 50 hours since.
In went the same oil and a US made Wix that crossed with the 3614.
It sees less than an hour per week but I rather use it then let it sit.
Got a new gem today so I changed the oil. A pristine 2013 Honda HRC216HXA. It's done a lot of sitting so the oil had to go.
Out: no idea
In: Mobil1 Euro 5w40
Have you found a good way to dump the oil on those? I have one. Kind of a pain to tip the mower on its side. To keep the oil drain pan from scooting away, I have to put some things down so it can push up against a wall. I have the HRN version though with the GCV170.
Not really. I just turn it on its side. I just use a little cup that holds 16 oz. I lean the mower on its side but not completely on the ground and let the majority of it come out. Then I put it back and empty the cup and then lay the mower on its side completely and let her rest drain out for 10 minutes or so.
I use the extractor pump I use for the Mercedes. Put the non-fill side on a 2" board and I extract through the fill port until it makes slurp noise. Easy and clean.
