Post your latest small engine oil change
South Carolina
Little Wonder Delux model edger (classic from 1978) Out: 10W30 Pennzoil Platinum In: SAE 30 STP Heavy Duty (Amalie)
MI
Honda hcv160 push mower. Air filter cleaned as this mower was bought new this sesson Out: factory supplied oil In: Royal purple HPS 10w30 Craftsman snowblower with 5.5hp Tecumseh motor Out: unknown black oil (flushed with entire quart or Mobil super synthetic 0w20. Oil was very clean after flush) In: Rotella gas truck 5w30 Both filled with ethanol free (rec fuel) and ran for several minutes and oil level checked. [Linked Image]
MI
So I figured I might as well do all my OPE. Karcher power washer Out: Royal purple 10w30 In: Royal purple 10w30 Ai-power generator Out:some Royal purple ( forgot what I put in it) In: Rotella gas truck 5w30 [Linked Image] [Linked Image]
Central Virginia
Originally Posted by Astro_Guy
Originally Posted by Macsignals
It will only run reliably on partial choke, will be draining/washing the gas tank and changing the shutoff valve, filter and lines soon. If that fails then an Amazon carb is going on.
Have you considered running a fuel system cleaner through it? Something PEA based like Redline SL-1. It might be worth a try if you already have some. A Wawa station out my way just started selling Ethanol free gas, and I am thinking of using it in everything that sits idle for long periods. That includes the generators.
If that's a Briggs metal carb, they are pretty easy to take apart and clean. I just did one on a Toro mower and it had a plugged main jet. You may just be able to unscrew it from the bottom of the carb bowl (looks like a drain plug) and run a wire through it. Most of the times you just need to clean the carb but don't know what you have. If it's a Nikki (worst design I have ever seen) they are more temperamental but still not hard to take apart and clean.
L.I. NY USA
in my pressure washer, Honda GCV160 motor, 10w30 Motorcraft blend with a few ozs of Castrol HD30. Same in my Subaru 175 motor on my Mower,closer to 2/3 Moto and 1/3 HD30. No oil filter on either.
Kansas
6.5 LCT engine on the log splitter. Drained 20 ounces STP 10/40 replaced with Mobil 1 10/30 for easy winter pull starts. I really like the engine. Roller bearings on both sides of the crankshaft. Smooth running easy starting. Great on fuel.
Connecticut
Craftsman 29" snowblower - 11.50 TQ Briggs and Stratton OHV Out: 3 year old Supertech 5w30 (last time serviced) In: Castrol 0w40 Replaced head gasket (reason for service). Had a blown head gasket from overheating. Had a mouse nest in the blower housing and customer did not notice. Also adjusted governor, since it was running at 2600 RPM (fixed throttle engine, no throttle lever).
My heart is in Dixie
I stock many flavors of ope oils. I work on many out of my garage. The usual sae30(both ND and hdeo), 10w30hdeo, 20w-50. Also syn in 0/5w-20, 5w-30, 15w-50 and 20w-50. My personal fleet sees everything from syn 0w-20 to sae40. Most usually see what the car sees, usually syn 0/5w-20.
Michigan, USA
John Deere LX188 w/ 17HP Kawasaki Left the filter on, run them for two changes typically. Out: 5w40 Mobil Delvac 1 In: Remaining leftovers of 10w30 Valvoline Premium Blue SB HDEO, 5w30 QSUD and 10w30 Meijer/Warren Oil Full Synthetic. If my math is right based on the amounts used it's about 8w30 mixed brew.
Pennsylvania
John Deere D140 Lawn Tractor with 22HP B&S V-Twin. Five years and 145 hours on the machine. 30 hours on this oil for the season. Out: 10w-30 Mobil1 High Mileage (3.5 HTHS) In: same. Left the TG3614 filter in place for another season.
Pennsylvania
Billy Goat leaf vacuum with Honda GSV190. New machine this fall; estimated 8-10 hours. The manual calls for 10w-30. Out: Factory/Dealer fill. Whatever it was, it ran out like water. I am having a hard time believing that it was any type of Xw-30. In: 10w-30 Mobil1 High Mileage (3.5 HTHS) This machine requires some strength for a long slow pull to start. It should be interesting to see how hard that rope is to pull the next time out.
Americus, GA
Toro Timecutter HD 54" Out: 2.5 Qt. Super Tech SAE 30 HD Off: Mobil 1 M-103A In: 2.5Qt. Super Tech SAE 30 HD On: NAPA Gold 1394
