Post your latest small engine oil change
My neighbor's Ariens ST724 - 7hp Tecumseh Snow King
Out: Black goo
In: Pennzoil Platinum 5w30
Also did a carb tune on it, runs perfect now!
Craftsman Pressure Washer with a 7.75 Briggs OHV...
Out - 10W30 according to my records
In- about 10oz of Pennzoil Ultra 5w30 and about 10oz of Pennzoil Synthetic Blend 5w30
B&S 18.5HP V-twin Intek in a Craftsman riding mower
2 Qts Napa Synthetic 10W30 (on sale)
Wix oil filter
checked the air filter
Added some fuel stabilizer
Air in tires
Ready for spring...............
JP
Kohler Courage SV590 19hp with 301 total hours. 35hrs this OCI.
Stens 10w30 conventional out, Stens OPE oil filter off.
Rotella T5 10w30 in, Fram PH3614 on.
Dont hate on the filter choice too much. My OCIs are super short on this thing and I've cut frams like this open after use on this engine before and never found issues.
1978 Toro 826 snow blower with 8hp Briggs and Stratton:
Out: PYB 5w30/Rotella T6 5w40 mix
Also changed the spark plug with a Champion RJ19LM and installed a new auger belt.
2014 Ariens deluxe 28, LCT 254CC. 1st oil change after 1 hour of operation. Plenty of metallic. 20 Oz of motorcraft 5w30 semi-synthetic, because it's what I had laying around.
2014 Honda 928WAS, drained FF after initial 2hrs of blowing 12+ inches of wet heavy snow. Refilled with AMSoil SS 0W-30. Lot's of metal "paste" viable in the drained oil.
1985 Ariens ST824 snow blower.
8hp Tecumseh
Out: MS5K 5w30
In: Mobil 1 5w30.
Greased all fittings.
2012 Honda HRX Lawnmower
Out - Honda 10w30 small engine
In - Mobil 1 10w30
Switched to M1 because it is much cheaper and maybe better. The mower takes only 12oz. Honda oil is just over $4 for 12.6 oz bottle. M1 was on sale for $3.99 a bottle.
My 2012 Gravely ZT XL's Hydro-Gear ZT2800 transmission, just a tad bit over 50 hours.
Out-Factory Fill 20w50
In-Mobil 1 15w50
2004 Airens Snowblower - Tecumseh 8.5hp:
Out: PO or FF 30w??
In: Maxlife 5w30
oil was in bad shape - looked like thick green pea soup. Warmed it up and changed it a 2nd time. Easier to start now.
2014 Husqvarna lawn mower - Kohler 4.5hp:
Out FF 30w
In: Maxlife 5w30
In: Kohler air filter
My mother's generator with a 14 HP single cylinder OHV engine.
Out and In: Peak conventional 10w30, 36oz.
Also cleaned and oiled the air filter, sprayed out Havoline conventional 10w30, soaked in Peak conventional 10w30.
New Rigid generator w/ Yamaha 12hp 357cc engine, post break-in.
Out: Original fill conv. 10w30
In: Older version PU 10w30
Didn't quite have enough so added a small amout of green GC to fill the base. Runs quietly.
