Opps! Wrong thread topic. Should be in "what are you working on...."Not auto related - Door closer kit and a lab jack.
The refrigerator door stopped self-closing a few months ago. Noticed yeaterday a pile of black powder on the floor under the bottom door hinge. Ordered a door closer kit; figured I'd do both the refer and freezer door.
https://www.appliancepartspros.com/whirlpool-door-closer-kit-4318165-ap3103517.html
Most of these appliance parts places post DIY videos. In one, the guy took the entire door off (screw that). In another, the guy left the door in place and supported it piece of wood and worked on the bottom hinge. I think this is the way I'll do it.
I measured the distance from the floor to the bottom edge of the door for the block of wood. I measured ~5.125" but hard to tell with a tape measure. I have a lab jack someplace in the garage; I just ordered one from Amazon; I ordered a 6x6 jack. Other than in a chem lab, this is another perfect use for one.
https://www.amazon.com/dp/B07TDQ5XMQ?ref=ppx_yo2ov_dt_b_product_details&th=1
It'll be a few days until the parts arrive.
Got some time to replace the refer door bottom hinge parts. Pretty ingenious way to affect self closing. The worn parts lasted +20 years.
Tools:
- 1/4" drive, 5/16" socket, short extension and ratchet.
- Plastic forked panel pry tool.
- Flat blade screwdriver.
- Small plastic faced hammer.
- Lab jack.
- Remove bottom vent panel.
- Vacuum out all the dust bunnies. Looked more like a bag full of loose, gray cotton balls.
- Support refer door with lab jack.
- Remove hinge cams from door and case.
- Use panel pry tool and hammer to unseat hinge cam from door. Remove cam.
- Remove hinge cam from case hinge bracket.
- Re-assemble in reverse order with new cams. (I had to pry up on the door hinge slightly to get the three fasteners to line up).
Hinge cams - Worn cams (top); New cams (bottom). Cam with stem goes to the door.
