Post your latest oil change
Twin Cities MN USA
Mazda just changed with M1 0w30 and Fram Ultra. This weekend Dakota will get the same oil and filter change. Ranger was just purchased a month ago, oil change with M1 0w20 and Fram Ultra.
Ca
2013 800 RZR M1 15w-50, Wix filter, Wally 75w-90 trans/transfer case and rear differential. Polaris Demand Drive in the front diff.
Southern Indiana
2013 Honda Rancher 420 Out: Rotella 15w40 In:Rotella 5w40 3.2 qts OCI was just under a year. We don't use it that much. Planned on changing the filter and thought I had one left. Ended up not having one, I'll have to order some and swap it out. The Quad feels and shifts smoother with the synthetic Rotella. Won't be going back to 15w40.
MO
2015 Can-Am Outlander 450L purchased in 2016 137 miles 28.0 hours Out: factory fill In: BRP XPS synthetic blend on oem filter What a major pain to change oil and filter on this thing. Took at least 20 minutes to remove enough plastic panels just to access the filter. Then about another 45 minutes to fit everything back together. Factory oil looked very clean still. Oil filter was cruddy from all the break-in gunk. I may just do a drain and fill anually or 50 hours and only do the filter every 100 hours since it is a real hassle. Anybody running an outlander on non-oem oil? $50 for 3 qts plus a filter is sickening.
Florida
2006 CRF450R & 2006 CRF250X, engine rotella t4 15w40 trans side Honda HP transmission oil. Sons 2019 Kawasaki kx85 transmission only Honda HP transmission oil.
Also serviced air filters w/ Belray foam filter oil (super sticky)
Service performed 03/20/2019.
Sask, Canada
My 2000 polaris magnum 500, not sure what hours on the oil, maybe 20 or 30..... Put in last fall, was some 5w30 PYB and a little bit of Motomaster 5w50 and Fram ultra filter.
I kept the filter as the hours were not bad. In went Conventional 10w30, Co-op DMO CK4.
She is all greased up and tossed in a new fuel filter. Ready to drag the arena for the summer.
2015 John Deere Gator 825i
OCI: around 50 hours + or -
Out: John Deere 10w30 Dino & John Deere filter
In: Pennzoil Platinum 10w30 & K&N filter
Wanted to switch to a full synthetic will all the start/stopping and torquey things it's used for on the farm. So far it runs much quieter on the PP.
2008 Can Am Outlander 800 Max XT
out/in Amsoil Formula 4-stroke 0w-40, Hifiltro HF152 filter.
Cleaned and re-oiled the AFE Proguard 7 cone filter and pre filter. (custom adapter}
