Post your latest oil change
Granddads 1999 Arctic Cat 250 2x4
out: Arctic Cat ACX 0w40 Arctic Cat filter
in: Arctic Cat ACX 0w40, some leftover Arctic Cat 5w50, and some Valvoline 10w40 Synthetic Motorcycle oil. Cat filter. Had the cases apart to change the stator pickup coil and ended up needing more oil than the oil change kit gave me so thats what it gets. Going to change the filter in a couple hours incase some old gasket material made it inside.
2019 Chevy Silverado 6.2l
20,118 total miles on truck
10,000 miles on oil
AMSOIL ASM 0w-20 out/in
AMSOIL EaO17 filter
2019 Kawasaki Mule SX KAF400J
Out: 1.4 Qt. Valvoline 10W40 4 Stroke
Off: FRAM Force 4967
In: 1.4 Qt. Super Tech 10W40 Full Synthetic Motorcycle
On: FRAM TG4967
Transmission
Out: 2.33 Qt. Factory Fill
In: 2.33 Qt. NAPA 80W90 High Performance.
This thread needs the title to include "power sports" in some way. It pops up in the new posts section without having to go to the power sports forum.
2016 Yamaha Viking
Out 2.5qts Valvoline ATV/UTV 10w40
Off Fram PH6017A
In 2.5qts Valvoline ATV/UTV 10W40
On Nutron 204
Yearly oil change just in time for the plowing season.
Recently changed oil in:
2018 Arctic Cat Alterra 500 4x4 ATV
2020 Sea Doo Spark 900HO jet ski
2014 Husqvarnva/Craftsman 19HP riding mover
Unknown year Toro push mower
2001 Yamaha 50HP outboard
All using Delo 400 XSP 5w-40 full synthetic
Oil filters are all OEM
Changed the oil in 3 4wheelers.
2 Yamaha Kodiak 450s and a Yamaha Grizzly
They all had a Rotella 15w40 T6 and 5w40T6 mix with super tech oil filters
They all got refilled with the same mix and again Supertech oil filters
Did up the 2000 Polaris Magnum 500. I don't bother with the crank case oil and just do the reservoir. Out was the conventional 10w30 CK4 DMO and in went semi synthetic 5w30 CK4 DMO.
Inspected the hub oil level, which was good. So she's good for the next cold spell and snow we are supposed to get.
Cfmoto Zforce 800ex
Out: factory fill and factory filter
In: maxima premium 4stroke 10w40 and hiflo HF152 filter.
2021 John Deere Gator XUV560E
Out: 10w40 Maxima Premium 4stroke and a Baldwin 7165 filter.
In : 10w40Maxima Premium 4Stroke and a Supertech ST3614
filter.
125 hours on machine and 25 hours on the oil.
2023 kawasaki brute force 750i
out oe oil and filter
in kawasaki filter and kawasaki s4 10w40 synthetic engine oil.
2019 Yamaha Wolverine x2. 2400km. Out was unknown with Yamaha filter. I assume it was Yamalube as we know the previous owner regularly serviced it at the dealer.
In went Yamalube 0w40 with OEM filter. There are some new NGK plugs to go in as well.
I usually won't pay the ridiculous markup on this stuff but it was for the business and I was in a pinch and did not have time to dig for alternatives locally.
2000 SkiDoo MXZ 600 chain case oil.
Out: Amsoil chain case oil and more metal glitter then anticipated. Flushed it with 75w90 ST and ran it a bit on the lift, then drained that out.
In: Amsoil 75w110 SVG I had on the shelf.
I run Redline Heavy shockproof in the chain cases of my 1200's. 10k miles on my '09 and no issues. Electric reverse still works fine and barely needs any adjustment. No glitter either.
2016 Yamaha Viking
Off Fram PH6017A
On Nutron 204
Have you noticed anything negative using the Valvoline ATV oil? I felt as if the clutch slipped in my side x side using it. Any oil usage?
2023 kawasaki brute force 750.
out: kawasaki filter and oil
in: kawasaki filter and amsoil formula 0w40.
Did up my Polaris Magnum again. I don't keep track of hours or miles on it. Its had a hard summer of pulling the drag and quadivatorand pushing snow all year. Out was the DMO 5w30 and Fram Ultra 6607.
In went DMO full PAO 0w40 and another 6607. I had done the hubs and transmission a couple months back already. With the carb back in action she is ready for a brutal winter again.
2008 chevrolet colorado lt 4x4 3.7. Castrol Edge 5-30 5 Quarts, 1 quart of Quaker State full synthetic 5-20. Fram Tough Guard oil filter.
Sorry for the delayed response. No issues at all. Never felt the clutch slip or issues with oil usage.
