Post your latest oil change
2012 Mazda 3 iTouring
117200 miles
In: 4.5 quarts of Mobil 1 Extended Performance High Mileage 0w20
Mobil 1 M108a filter
Out: The Kirkland 0W-20 I ran in it for the prior 5500 miles.
Wix 57002 filter.
I've been running Kirkland 0W-20in this engine for years, and I don't normally use High Mileage oil. When I was online buying Mobil 1 Extended Performance for another car in my fleet I accidentally ordered the Mobil 1 High Mileage. In the old 2012 Mazda it goes.
2024 Ram 2500 6.7 - 25,637 miles/ 774 hours
3,347 miles (7 months) this oci
107 hours since last oil change - Only changed due to winter idling
Oil sample obtained
Out: Chevron Delo XSP 5w40 and Fleetguard Stratapore LF16035
In: Chevron Delo XSP 5w40 and Fleetguard Stratapore LF16035
Sorry no pictures. Phone was in my car and wife took the car.
Daughter's boyfriend - his brother just picked up a 2013 Elantra ($3200) with 150k on it and leaves for school to SUNY Oneonta next week. Windshield sticker had that is was due with 3k interval. Dipstick showed it was overfilled some, I got just over 4.5 qts in recycle jug so they may have just added 5qts and been done. Car calls for 4.2qts. Looking through fill port everything was nice and clean and silver, no sludge around there at least and no varnish/staining. Filter mount area was the same, looked really good. No oil leaks underneath that I could see. It does have an exhaust leak that needs check/fix. Simple greened motor and engine bay for a clean up. Air filter clean. Need to check the cabin filter (forgot).
Out - 4.5+ quarts of unknown oil and white can Purolator L14459
In - 4.2 quarts of Castrol Edge 5W-20 and ECOGARD X10479. He needs to a double check at flat spot to make sure full.
Added some premix coolant to bottle to bring to full. Checked radiator cap and all was good and full. Brake fluid was full, didn't pull wheels, it will go to shop for check for NY state inspection this week. Filled windshield squirter with -25F to get that going through system. Needed both license plate bulbs and inner tail light bulbs, done. Front Kuhmo tires at 5/32" rears at 7/32" 2423 date code. TPMS light is on and my Autel TS508WF showed 2 dead sensors, checked Costco they said $65 each installed which they will have done this week. Told him to put the 7/32" up front now to even out wear.
Looked like actually a decent vehicle, clean in and out, perfect for sophomore in college. We'll keep an eye out for spare rims/winter setup for them. If not when these wear I'll at least suggest a 3PMSF version
2011 Toyota 4Runner
Miles on Unit: 303,360 miles
Miles on Oil: 5,010 miles (42 Days)
Sump: 6.6 quarts
Out: 6.5ish quarts Valvoline Restore and Protect 5W-30
In: 6.2 Liters Valvoline Restore and Protect 5W-40
Out Filter: Toyota 04152-38010
In Filter: Toyota 04152-YZZA5
You signature say Los Angeles, but we know you didn't buy the 5W-40 there. Are you in Australia right now?
I have a 2013 Hyundai Elantra and it is dead on the money full with 4.2 quarts. I laughed about the bulbs as mine that I picked up earlier this year had a bunch of rear bulbs out also. I think the Korean made bulbs just do not last in these vehicles.
They had that perfect mirror finish on all 4. He wanted to pay me for the oil and filter. I told him he paid more for the 4 bulbs than I did for oil and filter. I said get be an ice cream on the way home. It was tasty :D
2017 Subaru Outback 3.6R
Volume: 7 Quarts
In: Valvoline Restore and Protect 5W-30
Out: Mobil 1 Extended Performance 5W-30
Subaru OEM Tokyo Roki Filter
2021 Mazda CX-5 2.5L NA
Volume: 5 Quarts
In: Valvoline Restore and Protect 0W-20
Out: Mobil 1 Extended Performance 0W-20
Mazda OEM Tokyo Roki Filter
Girlfriend’s 2016 Hyundai Elantra. 152k miles, 4300 mile OCI
Out: 3.5qts Fram 10w-30 FS, Fram FD6607 filter
In: 3.5qts Fram 0w-20 Advanced FS, Fram FD6607 filter
It doesn’t burn a drop (yet). I’m cutting the filter and will post a thread on that soon.
1994 Chevy s10 with a 4.3. 116,000 on OD. Out: castrol edge extended performance 5w-30 with a Bosch filter. In: PUP 5w-30 with a wix protec 10k filter. Interval was 3k on this oci. I couldn't resist getting 5qts of pup for $10 and a free filter 👍
