Post your latest oil change
I distinctly remember that when I scanned mine for available pids it was reporting no oil temp. Yet I got the cvvt temp option once I got the plugin.
If your engine is in the list above, I'd give torque pro + plugin a shot. It's old and stuck in time, but is great for dashboards.
It can be personalized in plenty of ways, including start with the vehicle, all the way to inverted view if you want to project it to a HUD. Works with BT and Wi-Fi dongles, etc.
No, “ (OS) Kona “
2016 Mazda 6. 2.5L 138,700 miles. 11k OCI 🤣🙄. Dumped whatever the local Ford dealer put in and replaced with GTX high mileage synblend with a carquest red filter. Set the oil reminder as it was turned off. 4000 miles I’ll see it again. Drain plug wouldn’t budge, not factory plug. Couldn’t get it to budge and rounded it a bit (Dorman). Had to pound a socket onto it and then hit the end of the ratchet with my hand a few times to get it to move. Peeled out some black rubber gasket and ran to AA for a new factory style plug. Plug was leaking when I removed the access cover. Still can’t understand why oil monkeys have to tighten everything with a 1/2 breaker bar.
I had the same situation yesterday with the neighbor's Town Car. Torque spec for the plug is 10 lb ft but I couldn't get it off with a 1/2" breaker. After 5 min i threw in the towel and used the MityVac clone. I alsobcant figure out why these apes feel the need to crank the plugs so tight...
2016 ram 1500. 5.7l hemi big horn. 126.210 mi
Out. --‐ 7qts valvoline extended protection high mileage 5w30. Puralator boss filter ... 3k oci no added oil
In ---- 7qts valvoline restore and protect mopar 339 filter lucas fuel treatment
Checked sir filter and cleaned throttle body
Replaced sway bar bushings - end links
Well, it was updated at some point in 2 years.
