Post your latest oil change
Correct. This is now start of round 3 of Valvoline Restore and Protect.
My valvetrain area is spotless. My oil filter mount is clean and shiny. No clue on pistons, I haven't done a borescope....yet, not that I could see the rings anyway without disassembly and not planning for that.
PCV was changed at about 60k and again last year at I think 113k. It has had BG EPR, HPL Engine Cleaner 30, 1qt HPL PCEO 5w30 (used like EC30 multiple times). Oil has been Mobil 1 versions, Pennzoil Platinum versions, Delo XSP, Shell RGT, Valvoline Restore and Protect with viscosities of 0W-20, 0W-40, 5W-30, 5W-40. Pretty much the same usage from all of the above.
If it it doesn't change any after 4-5 rounds, maybe more, I'll do a borescope in cylinders just to see. I think it's my driving style as I'm 6MT and it sees a lot of daily engine braking as I leave in gear even to stop signs etc. That puts more vacuum to pull oil through. Car runs great, normal highway cruise with traffic at 70+ mph gets high 30's mpg which = almost 600 miles on a tank.
Is that correct that you're likely to use more oil if you're engine braking a lot? I have a V6 manual accord and it burns about 1/2 quart between changes maybe that would be why. I downshift a fair amount when decelerating but tend to rev match as best I can.
2021 GMC 1500 Sierra AT4 3.0 Duramax with 90,500 miles. Last OCI at 88k.
Out: 7 quarts of Mobil 1 Extended Performance 0w-30 and carquest premium
In: 7 quarts of HPL premium 5w-30 CK-4 and STP XL
Short OCI as I couldn’t stand it any longer and had to get the HPL in there. 🤡
Also changed ATF, differentials and transfer case to Amsoil. My boutique conversion is complete!😜😜
Didn't want to try the HPL ATF? Did you already have the AMSOIL? I've heard good things about the HPL. No doubt the AMSOIL will do great though.
You nailed it. Already purchased the Amsoil quite a while back from @Pablo but just got around to changing it. I like Pablo and I like the folks at HPL. Spreading the love around a bit I guess. lol
not engine oil but changed my rear differential fluid and front transfer case on my CX5 turbo. easy job and even tho Mazda claims they are lifetime fills I figured at 45000 miles I would spend the $35 on a qt of mazda gear oil and change them..glad I did. both were filled slightly less than they should have from the factory.
2007 Cadillac CTS 3.6
178.5k miles, 3k OCI
Out: 6 qts Pennzoil Ultra Platinum 5W-30*, ACDelco PF2129G
In: 6 qts Castrol Edge High Mileage 5W-30, ACDelco PF2129G
Filter was on for 6k miles. *Topped off with 1.5 qts total during OCI (1 qt of various brands/weights of oil and .5 qt of leftover ATF :eek:). Mity Vac clone FTW!
Nice! Original timing set? Your CTS has almost triple the miles of my 08
Changing on Monday (excited to post, so I’m posting now)
2018 Fiesta ST (was stage 2 tuned now E30 tuned) I switched to E30 fuel 110 miles ago, so I’m changing it ASAP
47450 Mi
2506 mi (7.5 months) on oil and filter
Out - Castrol Edge (black bottle) 5w30
Off - Motorcraft FL910s
In - Mobil 1 ESP 0w-30
On - Microguard Select MSL51348
Will post my used oil analysis.
