2015 wrangler 3.6
Out Valvoline euro 5w40/ microguard select xl
In Pennzoil euro 5w40/ microguard select xl
Hard to go wrong with this torque on a drain plug. Most if not all that I've seen in passenger cars and trucks fall in this range. If you don't know for sure, couldn't hurt to check it to make sure it's still torqued to value after some usage.I used 25-30 lb-ft
Don't see too much usage of this around here. Where did you pick it up?Valvoline euro 5w40
It was on sale on Amazon for $26, decided I’d try it out haha.Don't see too much usage of this around here. Where did you pick it up?
That was a good deal.It was on sale on Amazon for $26, decided I’d try it out haha.
That would drive me crazy seeing the digital oil level not quite at the top2025 Nissan Armada Pro-4x
9,000 miles on engine
OUT: Motul Xcess Gen2 5w-40 (2,000 miles)
IN: 5.7L Motul Xclean+EFE 0W-30
Quaker State hot rod oil?My friend's "new" Wisconsin VG4D industrial 4 cylinder 30 HP on a 9" brush chipper
Out: black stuff but nothing bad, NAPA 1106 filter
In: 4 qts Rotella Syn 5w40 + 2/3 qt Quaker State Hot Rod oil; NAPA 1106 filter
Filter was $40, ouch! I thought it was an oil bath air filter, but no. I have to do some research.
The drain bolt was a 9/16" square drive pipe thread and was pretty tight. Can anyone suggest a torque value? I used 25-30 lb-ft.
It actually serves a purpose by helping me keep track of fuel diltuion. So far doesn't burn any oil but the level does rise every now and then.That would drive me crazy seeing the digital oil level not quite at the topWhen my ex wife had a BMW with one of those digital oil level gages I always would top it up as soon as that oil level went down by one notch
Oil change on this hot rod.1997 Explorer 5.0
Removed ST2 white supertech, drained out Resolute 5w30
Installed a MC820s an old stock non louvered one, and filled with Valvoline MaxLife 10w30
Good maintenance on your fleet. But why one truck and two newer Odysseys?Toyota 5.7L 89604 on the odo and 4925 oci
Out - HPL PPCMO 0w30 and amsoil eao15k04 filter
in - the same
2026 odyssey 2652 on the odo and….1000 oci?
Out - pennzoil Ultra Platinum 0w20 and factory Honda filter
In - same oil and CQP filter
2023 odyssey 44724 odo and 4080 oci
Out - HPL PPCMO 0w30 and amsoil ea15k09
Best suiting needs of the family for now.Good maintenance on your fleet. But why one truck and two newer Odysseys?
