Post your latest oil change
Finished! We did blue antifreeze with Kool It Additive, Cat Converter, Oil Change, CVT Fluid, Rotate Tires
Was the Cat necesserary? I've had only one experience with an aftermarket cat, probably going back to about 2015. It wasn't a good experience. Luckily the shop I was dealing with took the hit and replaced it with the OEM cat on their dime.
2007 Honda CRV
K24 - 165k miles
VRP 5w-30
also changed the PCV. yikes!
2019 Impreza Sport
31,089 miles on car.
4,032 miles since last oil change, ~6 months.
Out/In: PP 0W-20
Filter Off/On: Wix 57055
I have I think 4 more jugs of PP which is another 2 years worth of changes (4 changes).
Also replaced the Cabin Air filter with a Bosch HEPA 6092C and put a bottle of BG 44k Platinum in tank. Will follow up with a bottle of B12 in a future tank. My last can of 44k. Have a 12 pack of Amsoil P.I I just got. I use a FI cleaner every OCI and B12 once a year.
2018 Nissan Altima
In : Pennzoil Ultra Platinum 0w20, Fram Endurance 6607 with white wire backed media and e core.
Out : HPL PCMO 10w30, Beck Arnley Filter.
Ran the HPL for 10K miles, changed the filter at 5K. Also a Beck Arnley. Only observations was the old oil definitely had more a red hue to it than usual, and lost a few mpg's by going to a 10w30 instead of factory 0w20. If I was financially able I'd stick with the HPL. Got the Ulta Platinum for 23 bucks and the endurance for 8 at Wallys.
It had 400k plus i have aftermarket midpipe and borla exhaust. We did break in procedure and it flows better
2025 Toyota Prius Prime 1200km on the clock.
Out:Factory Toyota 0w16 and 10009 filter.
In:Pennzoil Ultra Platinum 0w20 and 10010 filter.
As a side note, my Japanese made M20A-FXS had a whole lot less debris in the factory filter then my brother's A25A-FXS (US or Canadian Made?? Do they build engines in Huntsville Alabama?) in his new Mazda CX50 Hybrid that uses the powerplant from a Rav4 Hybrid. But is actually more fun to drive, being a Mazda.. Almost the same engine, one loaded with grit and crap at 400km, the other with a quantity that i would quantify as normal for a new engine.
‘17 Hyundai Sonata 2.4L GDI 60K miles
Out : M1 0W30 ESP with Fram Endurance
In : R&P 5W30 with Car Quest Premium
My first run of R&P on this Theta II 2.4L engine . Mainly want to check if oil consumption can be improved over the course of upcoming my 3,500 mile / 6 month OCI .
What kind of consumption are you currently seeing from this engine?
About 1 - 1.5 qrts. over my 3,500 mile OCI . My driving habits flip flopped to do 80%+ interstate and highway driving now , so I’ll get a better idea with this new oil change how the oil consumption is responding to VRP .
