And probably haven’t had the valves adjusted??1ZZ-FE still running strong , nice![]()
2013 Suzuki SX4 Sportback, 98026 miles.2013 Suzuki SX4 Sportback, 92655 miles
Out: Pennzoil Ultra Platinum 5W-20 (changed at @85K miles); Purolator Boss PBL14477 filter
In: Castrol Extended Performance 5W-30; Bosch Premium 3325 filter.
Wood panels in the engine bay? What’s going on here?Friend's 2010 Nissan Frontier XE 2.5L
Mileage: 98,190
OCI: 12 months, 6359 miles
Out: Havoline High Mileage synthetic blend 5w-30, Fram TG6607
In: 4 qts Cam2 Superpro Max synthetic blend 5w-30, 1 qt Amalie Elixir synthetic 5w-30, 2017 Fram TG6607 and Denso 143-3657 engine air filter
I'm not disputing that Kirkland will be totally fine in your usage, but there's no way it contains PAO. PAO is expensive to where even Mobil now purchases GTL from Shell cheaper than they can produce PAO themselves, for use in products like Mobil 1 EP. Kirkland/Supertech made to meet the lowest price-point possible for the high-pressure buyers of Walmart definitely does not contain PAO.Project farm did testing, Kirkland oil was great. Same as Mobil 1 if I recall especially If you change it every 5000 miles/ lower interval. I do plan to change it every 5k miles. It's a PAO 3 oil if I remember correctly. Will have to check!
Let me do research. My wording is incorrect I imagine so I apologize. Did a lot of research to try to understand differences between conventional and synthetic. The grading of oil I'm looking for is why people say an oil like the regular 0w20 Mobil one is not "actually" a full synthetic. Let me get back to you with the correct name.I'm not disputing that Kirkland will be totally fine in your usage, but there's no way it contains PAO. PAO is expensive to where even Mobil now purchases GTL from Shell cheaper than they can produce PAO themselves, for use in products like Mobil 1 EP. Kirkland/Supertech made to meet the lowest price-point possible for the high-pressure buyers of Walmart definitely does not contain PAO.
I'm a noob around here. Don't waste too much time trying to find the correct verbiage, as what some find acceptable, others will find reprehensible.Let me do research. My wording is incorrect I imagine so I apologize. Did a lot of research to try to understand differences between conventional and synthetic. The grading of oil I'm looking for is why people say an oil like the regular 0w20 Mobil one is not "actually" a full synthetic. Let me get back to you with the correct name.
