Post your latest oil change
Neighbor's 2013 Toyota Highlander LE 2.7L
Odometer: 168,086 miles
OCI: 4,849 miles, 6 months
Out: Chevron Supreme 5w-20, Toyota 04152-YZZA1 filter
In: Rotella Gas Truck 5w-20, 04152-YZZA1 filter
New Cub Cadet XT1 LT46 with Kohler 22HP: First oil/filter change at 1.2 hours. Another oil/filter change today (5.6 hours) with AMSOIL Small Engine 10W-40. I also removed that crappy plastic OEM quick-release drain valve and installed a sturdy metal ball valve. It's a Grasshopper Part# 143610.
Those plastic drain valves always make me nervous. Way too easy to turn.
My 2012 3.7 F150
272,977 miles
Out: Castrol EDGE Extended Performance 5w30, Pentius PLXL 10575 filter
5,251 miles on that oil/filter
In: Castrol Euro 5W30 API SL, Pentius PLXL 10575 filter
Was going to go the HPL route, but I have to turn in a monthly maintenance report for work with expenses, so it makes more sense to change my oil once a month and not waste the HPL.
My daughter's 04 Grand Cherokee. Since it's hit 225k miles and has developed a slow rear main seal leak (that seaps onto the exhaust pipe) I've decided to use HDEO in it, at least during Spring through Fall.
Out: mix of Delvac 10w30 and Kirkland 5w30 and a Microgard filter in the FL1A size
In: Kirkland (made by Chevron) 15w40 and an old NAPA 1515 (FL1A size) from my stash of Ford filters.
I think I would do another early OC with that much debris on the first change.
Yes! Another one is expected to be done at more or less 2500km on the clock.
Wasn't expecting that much to be honest. The early oil change in my Prius never showed that much debris.. i opened the filter and saw perhaps 5 or 6 flakes. Not much more if anything.. Japanese vs US assembly perhaps? Prius is made in Japan and the CX50 is built in Alabama.. do you know if the NA bound A25A are US or Japan built?
I'm at just over 4300 miles on this OCI with just over 120k on vehicle. I just added 1/4qt to top it to full line, he added 1/2 a short time ago.
That puts me at 3qts of "top off" over the 4300 miles. Maybe that's some of the Volatility that @JAG tested with the DELO 5W-40? Maybe it's the longer highway drives to Virginia and back? Maybe it's just my Accord? PCV was done very recently but it's always used some oil since I got it. Either way we'll keep it topped off as normal and I'll change it next time the car is back. This was the first run on the Delo if that has any impact like others experience when switching.
Sounds like a candidate for some Valvoline Restore and Protect. Piston rings might be stuck.
