Post your latest oil change
My 2007 Honda Ridgeline RTS
Odometer: 109,211 miles
Change interval: 13 months, 4,931 miles
Out: Cam2 Superpro Max synthetic blend 5w-20, Fram FPS7317 filter
In: Rotella Gas Truck 5w30, K&N HP-1008 filter. This RGT oil was 50 cents a quart from the 2019 Autozone clearance.
Also changed transfer case fluid.
A little early (again) on this oil change, by about 5-600 miles this time though, instead of 1500. This is my third round with the Valvoline Restore and Protect 5W30 for a total of over 7700 miles driven using this product.
The previous fill saw less consumption than the first. I was approaching 500 miles since I last added a quart, and a quick check on the dipstick shows about half a quart low. I'm unsure if I should expect any further reduction in oil consumption or not over this third fill but I'm hoping I will.
I drained out 4.5 qts, refilled with 5. I wanted to try the Fram Endurance so I got one and installed that over the OEM filter I had last fill. I was surprised by the quality and weight of the FE compared to an Extra Guard or Tough Guard, but still less robust feeling than the OEM.
Also added Gumout All-in-one to a tank of 93 octane Synergy TopTier from a Mobil station and did a transmission fluid change (drain and fill). See my thread about that in the maintenance section.
I rented a hoist to do my oil cooler lines in my Burb so I invited my daughter’s boyfriend to do some wrenching in exchange for a free oil change and winter tire installation.
2002 Chevy Malibu 1.5 liter Turbo
Out: Oil change shop 0W20 and white filter.
In: Pennzoil Ultra Platium 0w20 and Fram Ultra 12060. The Ultra Ultra change.
Here is the Malibu on the hoist with the shiny winter tires and rims.
I rented a hoist to do my oil cooler lines in my Burb. The first thing I did was drop the filter to drain out the oil from the galleys. The ADB valve has held and the oil cascaded into the pan. Disconnecting the oil cooler lines and draining them brought out almost another 1/2 a quart.
Out: Pennzoil Platinum Euro 5W40
In: Mobil 1 Euro Car 0W40.
Out: Motomaster OE Plus made by Champ.
In: Fram Ultra 10060
Here’s a shot of the old oil cooler lines. The Burb’s 6.0 has 262,000 miles.
Wife's 2020 Chrysler Pacifica.
In and out:
Supertech 20k 0w-20 and Supertech filter.
104,300 miles, usually a 5000 mile OCI but I did it a little early since I'm having knee replacement surgery next Friday.
I'd prefer a Mopar filter but Walmart never seems to have them in stock.
If it's full knee replacement, you may not want to kneel on the hard concrete to crawl under and back out from underneath your vehicle(s) anymore.
Takes about a full year to get most-all of your leg strength back, so be patient and do all the exercises. Thick, stiff foam and/or knee pads from Home Depot helps those that refuse to give up their DIY / at home oil changes.
Yeah, I already had the other one done last year. I sit down on the creeper first, then lay down, it's not too much trouble.
Changed oil in friends 09’ Focus. It was my old coworker who passed away in 2023. His nephews driving it now.
Out: Delvac 1 5w40
In: mix of some Valvoline Euro 0w40 and 2.5 quarts Valvoline Restore and Protect
Left the OG Ultra on for another 7k
390k on car also.
Swung by advance near his place; clearance table had Rotella T1 30 at $26.77. Clerk scanned it, showed that price. We walked right out.
2020 Hyundai (Tucson 2.0L Nu engine)
OCI: 6 months, 3,300~km | 25,000km on the car
Out: Pennzoil Platinum Euro 5w40
Filter out: OEM
In: Castrol Edge 5w30 M
Filter on: OEM
Edge 5w30 M seems to be an uncommon oil. Picked up 12L online at a decent price. Has API SN Plus, C3, BMW LL-04, and a couple of Mercedes approvals. Made in Italy. Date code suggests it was manufactured in 2010, if I remember correctly. Cool bottle design.
Castrol EDGE 5w30 M seems to be an uncommon oil. Picked up 12L online at a decent price. Has API SN Plus, C3, BMW LL-04, and a couple of Mercedes approvals. Made in Italy. Date code suggests it was manufactured in 2010, if I remember correctly. Cool bottle design.
It is a nice bottle design. What does the "M" stand for or represent?
That's a good question. I have no idea. There's also an overlapping Castrol EDGE 5w30 K which has the same C3, BMW, and Mercedes approvals, but has a few more manufacturer's approvals (Porsche, VW, Renault) and is SP instead of SN Plus.
New to me 2018 Toyota 4Runner (sold the Accord & Jeep), 89,217 miles, unknown but fairly short OCI based off oil color on dipstick
Laundry list of items done, here we go:
Out: Unknown engine oil & filter
In: Quaker State Ultimate Durability 5w30, OE Toyota Filter
Out: Unknown or Factory Transmission Fluid
In: Genuine Toyota ATF WS
Out: Unknown or Factory Front Differential/Transfer Case Fluid
In: Valvoline FS 75W-90
Out: Unknown or Factory Rear Differential Fluid
Out: K&N Engine Air Filter
In: FRAM Ultra Air 10835
Out: Unknown Cabin Air Filters
In: FRAM True Air CV10285
Bought her at auction for the wife in the paint & 7-seat upholstery that she always wanted, gonna fix her up to haul the family & 4,500 lbs of Bobcat MT100 & trailer 💪🏻
OE Genuine Toyota 75W transfer case fluid at +$50/liter? No thanks.
Stick around for an update post-repair!
I actually overlooked the transfer case as it sits right in between the transmission output and the rear driveshaft. I did not change out the fluid on it (sorry for lying folks) and I'm currently researching equivalent fluids to Toyota's 75W Transfer Case Gear Oil (which appears to be Shell TF0870) to not pay more than $50/qt or L.
