Post your latest oil change
2014 Hyundai Santa Fe, 2.0L DI Turbo, 103,424+ miles (son's)
4300 mile OCI
Out: Mobil 1 5w-30, OEM filter
In: Valvoline Advanced Syn 5w-30, OEM filter
Added: about .25 qts. during the OCI.
I wanted to try the VRP, but son picked up the wrong oil :unsure:. Hopefully he'll get the VRP next time--I think the H/K 2.0T will be a good test-bed for that oil. The view through the filler hole reveals shiny parts, but the oil cap inner side shows heavy dark stains. The dipstick is fairly clean but has a little varnish on the upper (dry areas). Despite it's poor reputation, this engine runs really smooth, makes good power and has a nice rumble sound at the exhaust. I miss that turbo on my wifes 2019 2.4L!
4300 mile OCI
I would love to have .25 of a quart of oil consumption over 4300 miles. My 2019 Sportage drinks **** near that every day on my commute for work.
22.5 Silverado 1500 5.3
29,347 miles / 1064.2hrs total on vehicle.
4,804 miles / 147.7 hrs on oil.
Out and in same as pic. Endurance filter this time.
2000 328Ci, 140392 miles. Last oil change on 21May2023 at 135764 miles.
  1. Out: Mobil 1 Euro 0W-40 plus 300 cc LiquiMoly MoS2 and Hengst E106H D34 oil filter.
  2. In: Exactly the same as what came out.
2021 Subaru Crosstrek Sport, 38283 miles. Last oil change on 13Nov2023 at @32500 miles.
  1. Out: Pennzoil Ultra Platinum 5W-20 plus 300 mL LiquiMoly MoS2 and Mahle OC1177 filter.
  2. In: Castrol Edge Extended Performance 5W-20 plus 300 mL LiquiMoly MoS2 and Pennzoil HPZ-37 Platinum oil filter. I had been hoarding this filter since the 2015.
2021 Subaru Crosstrek Sport, 42867 miles. Last oil change on 03May2024 at 38283 miles. Miles on oil = 4584.
  1. Out: Castrol Edge Extended Performance 5W-20 plus 300 mL LiquiMoly MoS2 and Pennzoil HPZ-37 Platinum oil filter.
  2. In: Mobil 1 Euro ESP 0W-30 plus 300 mL LiquiMoly MoS2 and Fram Ultra XG7317 oil filter.
  3. Extra: Replaced front stabilizer bushings with Subaru 20414SG001 bushings; sprayed Fluid Film on select underchassis components with minor surface oxidation.
2017 Toyota RAV4
2.5 4 cylinder
Out: unknown oil, unknown cartridge filter
In: Amsoil Signature Series 0w20, Napa Gold cartridge filter
1996 Chevrolet Cheyenne 1500
5.0 Vortec V8
Out: Havoline conventional 10w30, Schaeffer's Micron Moly EP, AcDelco PF1218 filter
In: Swepco 306 Supreme Formula 15w40, AcDelco PF1218 filter
2020 Kia Soul X-Line 2.0 MPI
30,000 Odometer Miles
OUT
Castrol Edge Euro 5w40 / Edge EP 5w20 Blend
Purolator Boss Oil Filter
3k OCI
IN
HPL Performance Plus 5w30 / No VII 10w30 Blend
STP Champ XL Oil Filter
2010 Hyundai Santa Fe 2.4 L. 196,000 on the OD. Out: M1ephm 5w-20 with Hyundai OEM filter. In: same. Also did tire rotation, and r&r serpentine belt. I do a 4k Oci. Auto tech
Is that your first Serpentine belt? Also how often do you rotate?
Asking for my 2019 Kia Sportage. I got 111k on the odometer, bought used three months ago with 98k
2nd belt. I like Gates for belts. Rotate twice a year. Every 5k would be a good time to rotate. Also on fwd or AWD front to rear and cross the rears to the front
