Post your latest oil change
New to me 2005 Toyota Camry 2.4 282K, best running car I've ever bought for 800 bucks.
Out: About 3 qts of Unknown Oil and Fram EG 4386
In: 4 qts of Valvoline Maxlife Synblend 10w30 and Fram XG 4967... it seems the 4386 is no longer produced.
The local Lowes has the PH4386 but I haven't seen the XG version.
Changed the slippy juice in both cars in the signature this week. 170,000 and 180,000 miles.
Each takes 5.3 quarts. Used costco/kirkland 0w20 and Microgard Select filters in both. The 0.3 extra was from various leftovers which was, admittedly a mix of higher grades. I estimate the result was just under 1w21. As the legendary Paul Harrel used to say: not enough of a difference to make a difference.
I did make a mistake: I forgot to prefill the filter. Next time.
out goes 6 quarts of Quaker State Full Synthetic 5w30 Dexos 1 Gen3 and a Champ XL PH44XL oil filter and in will be 5 quarts of older Mobil 1 5w30 Dexos 1 Gen2 and 1 quart of Quaker State 5w30 Dexos 1 Gen3 and another Champ XL PH44XL filter...
using up the older single quart Mobil 1 5w30 Dexos 1 Gen2 oil mentioned as that's what it is but my Denali doesn't require Dexos approved motor oil...
used zero oil and oil is still a light "iced tea" color after almost 5K miles and 8 months...OLM in the single digits on a 2005 GMC Yukon Denali 6.0 V8...
Bill
ya Dexos is irrelevant in a 2005 LS motor!!! I think you can run Crisco in these and it won't matter lol ;)
Soon ill be running my clearance stash of old gray bottle Pennzoil platinum 10w30(pre-natural gas formula) 2009 date code in my 01 Suburban and 09 crown vic 🥴 (y) 😎
Honda Ultimate Full Synthetic 0w20 in and out + cabin and engine air filter.
09 Prius, 218K
Out: Quaker State Full Synthetic High Mileage 5w30, Toyota F1 filter
In: Valvoline Restore and Protect 5w30, Carquest Blue 85394
Not sending this sample off to Blackstone, but I’ll do this one next time. I like this Vietnamese filter with the P-style O-ring.
2014 Kia Rio - 152K (2500 miles - short interval due to piston soak.)
Did another Piston Soak with Berryman B12 (used Sea Foam last time.). Did a good 24 hour soak with some agitation every 4 hours.
Out - Supertech 10W-40 synthetic blend and a Supertech MP9688 filter.
In - Supertech 10w30 HM Synthetic and a Supertech MP9688 filter.
Spark plugs and belt next weekend.
Oil filters supplied by @53' Stude and will be cut open next weekend and posted.
2017 Mustang GT Convertible 5L V8
Out: 8 quarts Quaker State Ultimate Durability Full Synthetic 5W20
(Wix/Affinia) Carquest Premium Blue Filter
In: 5 qts Quaker State Ultimate Durability Full Synthetic 0W20 and 3 qts Quaker State Ultimate Durability Full Synthetic 5W-20
(Champ Labs) Carquest Premium Blue Filter
Do you still have old stock of QS Ultimate Durability or did you mean QS Ultimate Protection?
This is from a site on YOUTUBE posted on 4/24 . The HONDA 0w-20 looks impressive .
View attachment 239384View attachment 239385
Here's another V.O.A. from a diffferent site which inludes VISCOSITIES , FLASHPOINT and T.B.N..
No mention of DEXOS . I'd use it for other vehicles stating DEXOS . Using non DEXOS P.U.P. 5w30 in the the '18 Accent and plan to use the P.U.P. 0w-20 in the FIT .
